I have done all the work my self appart from the inturstion bars as it requires some skill full welding. there isnt much to be done to GTRs only really 4 major things, intrustion bars/ stop light/ child restraints/and the engineer cert
every thing else is just normal RTA stuff.. I am only waiting on Skyline Performance to weld the bars for me, they are pretty busy...
I am pretty sure that you don't require an Engineers certificate to register the car. I have spoken to the motor registry and they indicated that to register car all that was necessary is a regular car registration inspection.
I would imagine that they would check then for side intrusion bars, stop lights and child restrainsts?
Sorry but that is incorrect... to check for side intrusion bars you would haver to remove the door skins and the RTA will NOT do this during an inspection they will turna round and say " can I have the engineer cert pls?" or something to those means.. you require a cert and the compliance spec as to the 15Yr rule standards. Guys as much as this sux you best off just doing it. Call John Wilson from AKZ Engineering he is the most help full and cheepest I found, Give him a call and say I refured you. I will post his contact number shortly...
Jap Manufacturer's started installing side intrustion bars in LATE 89' as the standard changed in 1990, most all cars you import from 1990 on WILL have them fitted as standard. but pre 1990 ie 89' only limmited few had them, mine - did not- it sux and is likely to cost $450 installed if I remove and strip the doors, which I have already done. There is nothing more tomrnting than having to pull appart you brand new baby. BUT the sooner it is done the sooner it will be registered and I can drive it (with out being dodgy :rofl: ).
John Wilson did my car. He is a top bloke and will give ya a discount if u mention how poor you are. (He takes pity on young blokes with awesome cars trying to get over rego) Is getting a GTR himself (He also owns two 20B cosmo's. He's the best engineer around and does a top job. Also he is one of the only other members of the public to have a set of keys to the old drag strip!
have a new job - so delayed rego on the R. will let you all know as soon as it goes over the pits and give a fiinal word on what needs doing :P (Guess i'll be the experimental animal!)
Good luck buddy hope all goes well!!! :D
note: waiting to say it.......:shake:
Godzillr - what did he have to do to it? did it have a cat for the exhaust (factory system?) did it have child restraints in the back? When i spoke to them all they said was i needed 2 x 200mmx200mm plates (with a both through the centre) and the cat. if it passed a normal roadworthy, it would then be regoed. no engineers cert required.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
