Hi Chris you going well with this build, nice sunroof save. I'm with you over preferring power over noise. Did you see these e-bay guards?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
can anyone tell me what the text is in the top corner of this?
R32_GTR_N1_Oil_cooler.pdf
found the part numbers for it
thess are the 9302 P/Ns
21308-RN581 - bracket
21300-05U20 - cooler kit
08110-6161E - bolts (10)
cannot find prices on these at the moment. looks like a phone call on monday to osaka...
Translation
1. "oil cooler installation will interfere with the existing air conditioning condenser". "if you want an air conditioning condensor, use a kit with this number" from this company Kenso phone them...
2. to install this will make air conditioning difficult!
Edited by WHITE gtt
ok:
tonight removed:
rear tailshaft
front tailshaft
engine ancillaries
this is so I can get the box and engine out a bit easier. the top two engine/box bolts are a bitch to get at. I also ground off the rusted wiper gear in the front. all of that went in the bin as its all past its useby date. I'll order new stuff after I get more money to do so. the rear wiper assy - I have a spare motor now - the nut was so rusted on that I had to cut it off as well and in the process destroyed the threads that hold the lot together. the engine will be out hopefully before the weekend. then the glass comes out and I start getting chemical burns from cleaning.
out of curiosity I pulled the head off the RB20. cylinder #5 rusted. cylinder #6 - black as. headgasket let go I figure and took the rest with it. EVERY line on htat head was catcus wit rust and crap. the entire lot is sitting out side ready for the scrap metal guy to pick up. I kept the cam covers and CAS.
next few days I'll yank the rest out now htat I can get to the back two bolts a bit easier.
  • Like 1
spent some time looking at wheel choice. looking at 17x7s in lenso specifically the DC6 in copper/bronze..
I would prefer simmons gold mesh but it looks like they are no longer made :blink: . I feel the lenso wheels would suit a red car - would like to hear feedback on this idea :(
been looking for a set of those. they seem to be made of unobtainium for some reason. those were my first thought until I saw the yahoo japan site.
yeah i bought mine from a guy i know that owns an import wreckers. he gave them to me for $550 with tires. we thought they were just the normal bbs rims until i got home and checked the text around the center caps. had the part number and all on it lol
Knowing you Chris if you think the BBS are best, you'll track them down! I like the Simmons option, I tend to buy second hand and refurbish, the modular construction means you could "tailor them". This interests me for GTS4s.
had simmons P86s (gold mesh) on a previous car. liked them. that was my goal but I cannot buy them anymore.
have found a 'donor' GTR for small bits and pieces local to me. that is going to get a fair bit of stuff taken off it I think. (thanks go to a darling downs member btw.)
02stagea,
ta!
its not the first one I have built though this is the first one that I have went into that much detail though.
talking to another fellow that totally rebuilt a 32 he thought he knew a fair bit about them before he started - he admitted he was wrong. I'm finding the same thing myself. there are that many 'minor' differences in these cars that its entirely NOT funny.
curretnly I'm working from 4 different chassis numbers to get what I want. 3 of them are Vspecs and one Oz GTR.
thanks to a QLD club member I actually worked out the paint on mine and what the car actually *should* look like internally and externally. if I can make it look like THIS as that is my colour I'll be more than happy.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
