started finding all of the spot welds on the rear panel. right side of this panel has a 3" push on it (next to tow hook.) and a rather large rust spot in the lower middle.
replacement is the only option here as teh panel guy needs to access the push in the floor to massage it back out. getting this panel off will be a piece of cake in comparison to the roof. panel is cheap and strangely enough - held in MLB!
Well there's one really good way to stop any potential rust issues in the roof....
CF ROOF!!!!
Sorry- had to be said. ha ha ha
I hope you keep it for a while and enjoy all your hard work... otherwise somone is going to get a reeeeeealy nice, re-built 32.
Cheers
Justin
CF ROOF!!!!
Cheers
Justin
agreed, I could never do this to a car then sell it.
and believe me I have NO intention of selling it. for what it cost to build I will never see the return on it.
I have 'film' for my camera so I will take a couple of piccies later.
everytime i see an update in here i am blown away with how much work you are doing. Once done it would be worth it to fly over, check it out and buy you a beer or ten. Love the r32's and will get one again one day soon once i have sorted a house out.
been buiilding cars for years though. you learn a few things along the way. it will not make NATS this your but there is a good chance it will next year. look at it then.
pop past tommorrow. you will get a better understanding of it.
I now understand WHY people are fussy with who fixes your cars. started finding the rear right quarter spot welds. 5mm of bog later....
panel is loose and ready to remove. used a air saw to trim it out
panel off. started grinding spot welds down at that point and tidying the rusted area in the middle.
removed section of panel. the rest was still attached to the car at this point. spot weld tool and a angle grinder took the rest off. note missing area in the lower middle.
closeup of removed panel. this is the inside of that rust spot in the low center of the panel
car side of rust spot before I cleaned it up
tidy up complete. it still needs a hit with acid to get the rest of it.
underside of rusted area . that blind nut holds a fuel tank strap in place. the idea is to make a patch up for this area and braze it into place with brass and lead.
all done and prepped with copper weld paint. the area to the right of the spare tyre area I have left bare for a reason. there is still a crease in the floor and I want to work out how to pull it back out.
top view of the crease. who ever did the repair on it simply sealed it with panel sealer and left it. it is NOT staying that way once I am done with it.
rear qtr panel where it was stick welded back on. I am debating how to tackle this still.
the top right corner had 5mm of bog in it.
I now completely understand why people choose high end shops to fix these cars.
it saves pulling crap like this apart for a second time to make it right.
  • Like 1
Spent all this morning under a silvia :S
another one of us pulling the car apart.
yep but mine now has a blue car cover over it for a few weeks.
I am waiting on bits to arrive so I can sit them in place and make panel adjustments on the car. (I'm talking about the roof here) I have not trimmed the A/B/C pillars back yet just incase I take too much off.
rear floor blow up . the parts marked in green/red are the fuel tank strap brackets.
Fig 75655+A is the one that is rusted a few images back. at $20 for the bracket it is going to be easier for me to buy a new one than try to save this one.
75656-35F01 is the part number for those playing along at home
  • 3 weeks later...
just took the right rear guard off.
amazing what you find when you start pulling a car apart.
this car has been down a LOT further than I have it now. most of the right rear side has been done at some point.
piccies tomorrow. I have my camera here but do not have 'film' in it... (doh!)
I intend to.
yet to order the rear guard. I need to clean up the all the joins first and then work out what needs fixing on them.
as it sits now there is a remnant of a rear guard there with the majority cut out with an angle grinder.
Im loving the fact that these cars are now old enough to have propper resto's done on them!
Love it!
yep almost 22 years..
been talking to a mate of mine in mlb about retrimming the door panels/seats. no problem for him but fabric choice could be fun. I want it to look like it does now colour wise . I'm told it will be close but not exact.
I'm going to the shop today so I'll take the camera with me.
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
