spent some time today trimming the areas left over from the old roof panel. result. new roof panel fits perfectly!!
placed an order (via japan) for some trim related stuff and new inner door handles. given that nissan is operating on a 4-5 day delay at the moment it should work out that I see this mid july with the rest of the shop orders.
hopefully by late AUG ->SEPT this thing will be sitting in a panel shop ready to be put back together. (if the local markets stay up and allow me to make $$)
usually under it after work or on weekends. latelyI have too many cars around it to do any serious work on it.
I can show you one thursday night if you like.
I now have a R32 GTR tank/straps and pump in my possession. also picked up another dash as well.
The R32 NISMO 280KMP/H Speedo will look nice
:) , since you in the habit of collecting Dashes
sounds good, either Thursday or Wednesday :) during or after meets.
don't' need one :) I am in the process of building a nismo 33 style dash for it. no TACH but it has a 4.3" LCD in place with a HKS CAMP2 atached to it.
got some more stuff today for it:
front reo
GTR front harness (this will fix my burnt fuse box)
front ABS sensors
a second front wiper cowl panel
FRONT A/C lines.
a second AC condensor.
I think WHIZZN got some more done on his as well.
also started working on the cruise control for this car (yes it will have one.) looked at a J30 maxima for the switch and light panels (cluster.) . the swtich fits in the GTST holes on the dash. the light panels I have yet to try. at worst it will be a cut/shut job.
yet to do the actuator side of it. would like to find a GTST/GTS4 with a factory cruise wheel before I resign myself to using a maxima one.
was actually going to pm you about a cruise control setup, as im interested in one for my 32. Interested to see how it all comes together. Was going to start working on stripping mine now im on holidays, but managed to separate two ribs from the cartilage in my chest...means no work being done now
cruise control for me is a complete custom job. my first approach is to pull the ENTIRE thing off a J30 maxima and work with it. if I do that then I can acess the unit via consult and do diagnostics on it. the other advantage is that the maxima unit is electric so I won't have vac problems trying to drive the thing.
second approach is to talk to my cruise control maker and get them to customize a module for me. the end result (from the outside) will be the same but with aftermarket units.
couple of picces of today's efforts.
2nd hand wiper cowl panel. this one is in far better condition than the other one I have. the white stuff is armor all. I give things like this a bath in it to renew them. the plastic bag is from the front bumper.
front GTR bumper now sitting in place. mate of mine pinched the box that it was in. behind that is a 2nd hand GTR reo bar. (thanks whizzn!!)
rubber seal - again 2nd hand and in far better condition than what I had. the harness and fuse panel in there is also R32 GTR (2nd generation) this fixes the burnt GTS4 harness I have currently. if the GTR one is close enough I may use it in place of mine.
Cool...
I got HKS F-Con ECU and is also thinking about the CAMP2, will pick you brain about it when i see you in Club event the next time
for those nutty enough to be looking at the idea:
cruise control
R32-cruise-cont-parts.pdf
there is a catch from what I can see. there are 4 harnesses for this car. mine has the extra plugs for the cruise units inside and tucked away on the harness outside so its definitely doable on this car. yet to ask nissan japan about what is still available though.
the overlay panel from the maxima is too small so thats not going to work. would be nice to find a used cluster that had the cruise overlay in there. I somehow do not like my chances there.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
