even the GTT isnt far off. i have a pair here that are destined for my better halfs VW. have been thinking about bolting them into my 33 (34 seats are a tad bigger), but they do require a small amount of works.
  • Like 1
give me a call first. lately I have not been working on it tat much. trying to do other things that do not cost a lot of $$ to do. harnesses being one of them.
got these today.
R32 GTR I'cooler piping and BOVs. I already have the brackets to mount this stuff. the rear mudflaps and fuse panel cover were an extra bonus.
now to work out what I am missing. I still need a GTR air box and BOV return pipe.
i have just finished reading this, chris mate, this is awesome, i honestly cannot wait to see this in person when you have finished everything, everything is so well thought out and planned, words escape me as to how awesome this build is.
finally spent a bit more time doing small things. drivers door harness has been rebuilt to take a factory door actuator instead of a aftermarket gun type so it will be a bit more reliable.
when I got all the GTR bits off whizzn they came with a GTR key. all the locks went to HA Reed Locksmiths in Albion today to get recoded and a spare key made. should have them back in a few days and that will fix the worn locks as well.
probably going to spend sunday doing another harness.
I'll be dropping off an airbox with some other stuff next week Chris, run out of time today
Only problem with it is that someone in Japan grinded half of the bottom bit away for extra cooling lol but top halfs alright :whistling:
started working on the engine harnesses tonight. that should take a week or so on mucking around and it will be done. my goal is to be able to fire relays with a diagnostic computer attached. if I can do that then the car should run once the engine goes in.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
