  On 01/01/2012 at 12:46 AM, Miguelone said:
Why not try a retrofit with the r33 240km/H dash with lcd screen?
nah. then I lose my torque gauge and the cluster is a different shape so it is not a direct fit.. the HKS peice does tach any way so it will have a digital tach and info meter similar to the more modern R34 GTR.
I have a few electrical tweaks to go on it - this is one of them
also this screen will double as a navi screen when the HKS piece is not being displayed. again its a tweak that I am used to having in the other vehicles I own.
this is a R34 obviously but you get the idea:
did that in 2008 to a mspec nur.
just ordered and paid for NEW heated mirror glass and the associated switch that runs it.
2nd last image of the car you will see it has blue mirrors. the original red ones worked but were missing screws. found these and the associated harnesses to run them. checked that the harnesses are supported by the car - they are. mirror glass was missing.
part numbers for those playing at home.
9636505U00 - Mirror RH
9636605U00 - Mirror LH
25570-71L00 - Switch
mirrors and switch were $290.
I am going to try and get the side glass next. nissan japan seem to be paranoid about shipping it directly to me so I am going to get a mate of mine to pick it up for me.
(repost - fixed images.)
  On 31/12/2011 at 11:43 AM, Chris Rogers said:
just bought this:
that will fit nicely into the GTR cluster that I have ( the tach is coming out.)
this in conjunction with a garmin GVN53 and HKS CAMP2 should bring this car into the 21st century quite nicely
already spoke to a speedo cluster repairer as well about making me an overlay with a clear area for it so it all looks factory.
only oversight I had was the amount that a sheet of the material makes - 5 overlays. so once done I will have 4 of them up for grabs in the factory grey instrument color.
Is this just a LCD Monitor with a VGA plug?
I have headed ones in my R32* but have never ever needed to use them and being in WA dont think i ever will. Maybe if i come over east ill go to the snow just so i can use them..lol.
I like the nav screen trick. May i suggest (if you can) edit your first post to include the complete list of part number so people can find what they are after with out going through the complete thread.
* VW not a nissan before you get excited
no. I could buy it as a VGA unit with a composite feed as well . could not be bothered as I have a custom interface already on paper for it any way.
this one is composite video only. I will use the unused radio buttons on the top left of the cluster to toggle between the units.
if I can get a admin on my side I will update the first page. there are a lot of part numbers in the 24 odd pages - that I do know.
I could not buy the normal mirrors.. I had picked up the blue mirrors to fix my red ones. I noted an extra two pin harness hanging off it. prior to this I had been in possession of 3 cars that were the same so I made notes of chassis numbers and with a bit of translation help found that this was a cold weather option. (the battery was the other - northern cars have a HUGE battery.)
  Quote
my van has the same idea except that it goes from navi to a camera. if I get bored I *MAY* do that as well to this car. need to get the overlay done and the HKS item here first.
I am going to use add on harness to add the 'missing' sensors that I I do not already have. I am not sure if front torque is on the data stream or not. never looked and I can't really look until I can power the car up and thats NOT for quite a while yet.
spent today talking to a instrument repairer in salisbury. explained what I was trying to do and he showed me a few examples of the work they do with dials . dropped the tach and indicator overlays off to them and said take your time.
I still need to take them the LCD panel for measurement so everything lines up correctly. I am also getting a new indicator panel done (top center panel with the green arrows and high beam icon.)
the indicator overlay is s 4 color piece and I'm told will be a bitch to make correctly. the aim with this one is to put a security word in black/red on there below the high beam indicator area. the cluster has a spot there for a extra light and that s what it is going to be. the light itself will be a LED out of a toyota starlet cluster, its the only thing bright enough to light that area and not take a nuclear power station to run it.. (I have 30mA to play with most lights take 2-300mA to run)
I will put up images of it once they get it done. for those thinking cheap ebay dials - nup! these are good enough to be OEM.
  On 16/01/2012 at 3:41 AM, Chris Rogers said:
got a call from nissan (locally) saying that all my stickers have arrived. perfect!!
they still make the GTST stiker !!!! for R32
wow...
Christmas for me!!!
I have:
new heated mirror glass
window moldings - set (flat ones that sit on top of the door.)
heated mirror swtich
new sun visors
all of the outside engine bay stickers
tyre placard sticker
new rear grab handle
I will do images in a bit.
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
