  • 3 weeks later...
couple of images of the modified cluster: (this is V1 - I'm not happy with how it came out.)
I had these done locally:
that entire panel (where the cruise indicator sits) has been redone. there is one issue with it. the security indicator
is inverted. it was supposed to be a red background with black text. a stupidly bright white LED lights it up. (I have a LED drop light under it for this shot.)
I am going to take it back to the people that made it for me and get the security area redone so it matches the rest of the panel.
at the moment its a bit hard to see unless you are on top of it.
this part came up ok apart from the inverted lower panel.
LCD panel in place. this is also V1. it needs to come up about 2-3 mm and the entire panel squared up.
this was done with a hand saw and looks a bit rough for my liking. again something I intend to take up with the
people that did it.
more to come. the interface and harnessing is next up.
yep. most of the electronics is getting done at the moment. my goal is to get the cluster done again and from there the switching,rev cam, HKS unit and navi harnesses.
ok started V2 of the dash.
V2 entails totally removing any evidence of the tach even being there.
started looking at it this morning and I reckon I can make a insert to fit on top , high fill,sand,chamfer and make it look like this:
(yes this is a nismo 33 item - concept is what I am going for. note chamfered edges around the screen)
so it looks like I will need another 32 cluster to work with..
(if you know of one - tell me.)
just put a request in for a set of N1 headlights, new from indicators,
purchased a new set of door catches (they were cheap!)
the catches should be here in a couple of weeks. they are part of a much larger shop order.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
