You're really doing this well and I admire it. Despite this, I am glad that mine came with very few body defects.
to be honest I have worked on much worse over the years that people were still driving around.
a FC holden wagon springs to mind. this came into a strathfield workshop in sydney and you could see through the floor once they moved the sheet of plywood around!!
the areas I can doing on this car are getting done because I want a straigh clean car. somthing I cannot find as most of the cars I have worked on in the last 11 years (I am talking 32's here) were rusted on the rear window, sills or cut/shut. that applied a LOT more to green plate cars.
as you can tell its all about the experience. I am not a chequebook racer and anything I can do myself I will.
those that know me personally pick up on that immediately.
the only part of this I cam not doing is spot welding it back together and painting - simply because I do not have a stable enough hand to wield a paint gun - frank at GT motors does!
2nd shot of roof panel being removed. there are at least 30 spot welds across the front of that. I have got the use of this cutter down to an art now.
the lower support panel does not have a single mistake in it.
another shot.
the brass seams are going to be cut with a dremel tool. a die grinder will be too big to trim those 4 points loose. the front corners are about 4 cm long and those will be fairly easy to do. the rear sides are 15 cm and possibly a pain in the butt. we'll see.
How are you going about the issue with the sunroof as per our discussion mate ?
Its good to see you are really pulling it down and getting the dodgy spots sorted, I hate seeing stuff just bogged up !
Im going to have to get my sills looked at at some point because idiotic previous owners of my car, decided that the little seem that runs along the bottom of the sill is an awesome place to jack the car from, Que surface rust.....
Edited by Nee-san
thats what was done here. believe me if the panel shop had to cut that car apart then reassemble it the cost would be a 5 figure exercise. I already know the cost of the panels involved (its the entire drivers side) and that isn't exactly cheap. in regard to crushed sills - cue $1k in sill panels and another $1k or so to fit them.. I am doing the cutting on mine and the panel guy is going to put them back. saves some of that bill.
after 10 minutes with a angle grinder GENTLY trimming around the brass marked edges of the roof panel - its loose.
and its off.
side shot. drip rails (top middle of door frame) still need cleaning out.
right side shot
right side front corner - the goldish line is brass filling. I still have to clean that up so the new panel fits correctly
upright shot. this is more for my reference to mark what the panel looks like. note rust spot in top right corner,
rust spot as seen from the bottom. this is the reason I pulled this panel off for replacement. it would cost as much to fix it (and have it rust again) as a new panel would cost. so I cut this off off. my aim is to do this once only.
removed panel. the worst part about getting this thing off were the areas around the drip rails at in the top middle of the door glass. they are VERY small spot welds and to get them off properly requires a dremel. angle grinder is too heavy for the job.
rear drivers quarter is next once I get my panel dimensions book. until then it gets a car cover tossed over it. I will still be working on it but in smaller ways. all the small brackets are going to be bought whilst I wait for this book to arrive.
R33 is here:
http://i64.photobucket.com/albums/h191/hakosukajd/R33dim.jpg
R34:
http://i64.photobucket.com/albums/h191/hakosukajd/R34dim.jpg
thats PART of what I am looking for. I still need more and the points that they use to measure from. the diagram is a bit vague to me.
pass. if I wanted a convertible I would have kept a varietta for a bit longer. I have a RAW that keeps giving them to me for a few weeks at a time. thats about as long as I can stand them - no space for anything.
yep. I'm not one to back down once I start something.
new dash,carpet,boot trim/carpet etc - arranged :)
no to the convertible idea. this thing twists enough with the roof panel off ..
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
