started finding all of the spot welds on the rear panel. right side of this panel has a 3" push on it (next to tow hook.) and a rather large rust spot in the lower middle.
replacement is the only option here as teh panel guy needs to access the push in the floor to massage it back out. getting this panel off will be a piece of cake in comparison to the roof. panel is cheap and strangely enough - held in MLB!
Well there's one really good way to stop any potential rust issues in the roof....
CF ROOF!!!!
Sorry- had to be said. ha ha ha
I hope you keep it for a while and enjoy all your hard work... otherwise somone is going to get a reeeeeealy nice, re-built 32.
Cheers
Justin
CF ROOF!!!!
Cheers
Justin
agreed, I could never do this to a car then sell it.
and believe me I have NO intention of selling it. for what it cost to build I will never see the return on it.
I have 'film' for my camera so I will take a couple of piccies later.
everytime i see an update in here i am blown away with how much work you are doing. Once done it would be worth it to fly over, check it out and buy you a beer or ten. Love the r32's and will get one again one day soon once i have sorted a house out.
been buiilding cars for years though. you learn a few things along the way. it will not make NATS this your but there is a good chance it will next year. look at it then.
pop past tommorrow. you will get a better understanding of it.
I now understand WHY people are fussy with who fixes your cars. started finding the rear right quarter spot welds. 5mm of bog later....
panel is loose and ready to remove. used a air saw to trim it out
panel off. started grinding spot welds down at that point and tidying the rusted area in the middle.
removed section of panel. the rest was still attached to the car at this point. spot weld tool and a angle grinder took the rest off. note missing area in the lower middle.
closeup of removed panel. this is the inside of that rust spot in the low center of the panel
car side of rust spot before I cleaned it up
tidy up complete. it still needs a hit with acid to get the rest of it.
underside of rusted area . that blind nut holds a fuel tank strap in place. the idea is to make a patch up for this area and braze it into place with brass and lead.
all done and prepped with copper weld paint. the area to the right of the spare tyre area I have left bare for a reason. there is still a crease in the floor and I want to work out how to pull it back out.
top view of the crease. who ever did the repair on it simply sealed it with panel sealer and left it. it is NOT staying that way once I am done with it.
rear qtr panel where it was stick welded back on. I am debating how to tackle this still.
the top right corner had 5mm of bog in it.
I now completely understand why people choose high end shops to fix these cars.
it saves pulling crap like this apart for a second time to make it right.
  • Like 1
Spent all this morning under a silvia :S
another one of us pulling the car apart.
yep but mine now has a blue car cover over it for a few weeks.
I am waiting on bits to arrive so I can sit them in place and make panel adjustments on the car. (I'm talking about the roof here) I have not trimmed the A/B/C pillars back yet just incase I take too much off.
rear floor blow up . the parts marked in green/red are the fuel tank strap brackets.
Fig 75655+A is the one that is rusted a few images back. at $20 for the bracket it is going to be easier for me to buy a new one than try to save this one.
75656-35F01 is the part number for those playing along at home
  • 3 weeks later...
just took the right rear guard off.
amazing what you find when you start pulling a car apart.
this car has been down a LOT further than I have it now. most of the right rear side has been done at some point.
piccies tomorrow. I have my camera here but do not have 'film' in it... (doh!)
I intend to.
yet to order the rear guard. I need to clean up the all the joins first and then work out what needs fixing on them.
as it sits now there is a remnant of a rear guard there with the majority cut out with an angle grinder.
Im loving the fact that these cars are now old enough to have propper resto's done on them!
Love it!
yep almost 22 years..
been talking to a mate of mine in mlb about retrimming the door panels/seats. no problem for him but fabric choice could be fun. I want it to look like it does now colour wise . I'm told it will be close but not exact.
I'm going to the shop today so I'll take the camera with me.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
