  • 3 weeks later...
yep. buying weekly bits. decided it was better to buy all the bits for it first and work back from there. going to do the interior next. that will be a panel at at time given some of those are $400 + each.
I have a R31 as a daily so I can concentrate more on this one when funds allow.
decided to order a NEW dash for it. bad thing is nissan local are saying NLA on the correct piece. they are coming back to me on the revised piece.
nothing new body wise. its still sittting on its side in gympie. I post up parts pix when I buy them. interior panels are next. all my plastic for the dash area is 2nd hand and has been sitting in boxes since I bought it. the dash pad will be new, the door and rear panels new and seats done in a 'GTR' type trim.
all of that is easily 6-8 months away.
interior panels - priced.
front seat belts ordered - $265 a pop. I am using S2 GTR (94) for the belts. rears I will probably use the same car for those. ( I have a northern model 94 GTR on file at the shop.)
As far as I can see all the rear belts under every part number are available.
Part Number:88844-01U00- Description:ベルト アツセンブリ-,リヤ シ-ト タング,RH Prod.M/Y:8905-9108
Part Number:88844-01U01- Description:ベルト アツセンブリ-,リヤ シ-ト タング,RH Prod.M/Y:8905-9108
Part Number:88844-02U00- Description:ベルト アツセンブリ-,リヤ シ-ト タング,RH Prod.M/Y:8905-9108
Part Number:88844-02U01- Description:ベルト アツセンブリ-,リヤ シ-ト タング,RH Prod.M/Y:8905-9108
Part Number:88844-01U00- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9108-9202
Part Number:88844-01U02- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9108-9202
Part Number:88844-01U06- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9108-9202
Part Number:88844-01U60- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9202-
Part Number:88844-01U61- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9202-
Part Number:88844-01U62- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9202-
Part Number:88844-02U02- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9108-9202
Part Number:88844-02U06- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9108-9202
Part Number:88844-02U61- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9202-
Part Number:88844-02U62- Description:ベルト アツセンブリ-,リヤ シ-ト タング RH Prod.M/Y:9202-
Part Number:88850-01U00- Description:ベルト セツト,リヤ シ-ト センタ- Prod.M/Y:8905-9108
Part Number:88850-01U01- Description:ベルト セツト,リヤ シ-ト センタ- Prod.M/Y:8905-9108
Part Number:88850-01U02- Description:ベルト セツト,リヤ シ-ト センタ- Prod.M/Y:9108-
Part Number:88850-01U06- Description:ベルト セツト,リヤ シ-ト センタ- Prod.M/Y:9108-
Part Number:88850-04U00- Description:ベルト セツト,リヤ シ-ト センタ- Prod.M/Y:8905-8908
Part Number:88850-04U06- Description:ベルト セツト,リヤ シ-ト センタ- Prod.M/Y:9108-
Part Number:88842-01U00- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:8905-8908
Part Number:88842-01U01- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:8905-9108
Part Number:88842-05U00- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:8908-9108
Part Number:88842-01U00- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:9108-
Part Number:88842-01U02- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:9108-
Part Number:88842-01U06- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:9108-
Part Number:88842-05U00- Description:ベルト アツセンブリ-,リヤ シ-ト バツクル Prod.M/Y:9108-
Part Number:88845-01U00- Description:ベルト アツセンブリ-,リヤ シ-ト タング,LH Prod.M/Y:8905-9108
Part Number:88845-01U01- Description:ベルト アツセンブリ-,リヤ シ-ト タング,LH Prod.M/Y:8905-9108
Part Number:88845-02U00- Description:ベルト アツセンブリ-,リヤ シ-ト タング,LH Prod.M/Y:8905-9108
Part Number:88845-02U01- Description:ベルト アツセンブリ-,リヤ シ-ト タング,LH Prod.M/Y:8905-9108
Part Number:88845-01U00- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9108-9202
Part Number:88845-01U02- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9108-9202
Part Number:88845-01U06- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9108-9202
Part Number:88845-01U60- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9202-
Part Number:88845-01U61- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9202-
Part Number:88845-01U62- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9202-
Part Number:88845-02U02- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9108-9202
Part Number:88845-02U06- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9108-9202
Part Number:88845-02U61- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9202-
Part Number:88845-02U62- Description:ベルト アツセンブリ-,リヤ シ-ト タング LH Prod.M/Y:9202-
ok, figured I would get in before everyone else bought all the parts up.
currently in the works:
new dash pad and vents
new interior door nd rear panels
door rubbers
rear belts (gtr)
  • 4 weeks later...
spent a bit of today working on the body. bit more cleaning and disassembly of thr rear subframe. been talking to fulcrum about getting it rebushed and they need it for sizing.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
