I have my HTPC for sale, it was built specifically to act as a HTPC and handle bluray decoding (though no bluray drive is included). It could also be re-purposed to act as a centralized media server.
Motherboard:
Gigabyte GA-MA78GM-S2H
Onboard ATI Radeon HD3200 GPU, HDMI with HDCP, 7.1CH HD audio, full onboard decoding of 1080P Bluray video and audio, ESATA, Firewire, Optical SPDIF out, DVI-D out.
http://www.gigabyte....?ProductID=2926
CPU:
AMD Athlon 64 X2 5200+ (Dual core, 2.6GHz)
HDD:
1 X Western Digital WD400 Caviar (40GB IDE) – System Disk
CASE:
ANTEC Overture II (With front panel painted black instead of original silver)
RAM:
2GB (2 X Kingston DDR2 800MHZ 1GB sticks)
OTHER:
DVICO Fusion Dual Express TV Card (Dual Analogue/Digital Tuners)
Dlink DWL-G520 108Mbps Wifi card
Pioneer DVR-215BK DVD-RW
Points of note:
The original PSU wore out, and was replaced with a generic one (350W). Due to the specialised design of the case and it’s matching PSU the generic PSU had to be modified (opened up and the cabling re-routed through a hole cut in the lid) to fit the case. Everything works perfectly the PSU simply has the cables sticking out the top instead of the side.
Does not come with OS installed.
I have had it running on Win XP with XBMC flawlessly and all controlled by the DVICO remote. Comes with driver cds and original packaging for all of the components.
Happy to demonstrate it working for buyers. I am also happy to install your OS for you and set it all up if you do not know how to do it yourself.
More pics can be found here:
http://users.superne...au/~blaik1/htpc
Asking $550
Located on the Northside of Brisbane, near Strathpine
Can post interstate if necessary (at buyers cost)
https://www.sau.com.au/forums/topic/339680-home-theatre-pc-htpc/
  • 2 months later...
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
