I just changed my RB25DET injectors to 740cc Tomei injectors. I am having a really really heavy petrol smell when i drive/stop/idle my car, is this normal? its really heavy petrol smell, no joke............my whole house can smell it if i didnt close the door to the garage when i get home........ any other way to make it not smell that heavy?
DOesnt sound tuned properly if its running rich as hell.
Do you have a cat converter?
pretty sure i have a cat converter , i have to ask my mechanic about that man, if he tuned it running too rich..i probably need to ask him retune it.....i will give him a call tomorrow to make sure! thanks
The fuel indicates leaking injector seals. Leaked fuel vaporize and you smell it through the cabinet. It will likely to leak or leak more violently under high boost pressure.
haha that was freaky, didnt read the whole thread before posting.. identical thoughts just worded different!
i smell it in and out of my car...............driving me crazy man!! so smelly!!!!!!!!!
champ if it is leaking from the injectors, the smell could be the least of your worries if your still driving this vehicle.. fire is a mutha f*ka in your pride and joy
get it sorted asap.
fire? are you serious?lol........i need to wait till next mon or tues to get it check man but i still need to drive this beast to work tomorrow!
If fuel is absolutely pissing out at the injector (but we don't know where yet), it's possible fuel can get inside the injector plug and start a spark that will ignite the fuel in the enginebay.
from what i see, there is no fuel/oil leaking around my injector......but i cant see some of them ...its inside the thing.......
If you paid a mechanic to install these injectors, you should take it back to him to find the source of the smell.
And yes, the smell is vapor. Vapor is the thing point in which fuel goes boom best.
yea taking it back tomorrow for them to check , i can smell it really heavy in my car as well.....not just outside the car :S
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
