If you have no idea about cars, stop driving it and take it back to your mechanic asap!
If your smelling lots of fuel something is definitely wrong. And yes fuel is flammable so it could be dangerous.
I agree with the above, stop driving it because you are clueless. I see 2 things happening. Scenario 1, the fuel is leaking in the enginebay and starts a fire, possibly a write-off situation. Scenario 2, the engine is being starved of fuel and running lean, the engine will run super hot and throw a bearing(s), melt pistons & valves, crack the piston rings, break the conrods etc, resulting in a rebuild that is going to cost 2k+.
good to see it sorted lad, lesson learnt eh?
PS. I recently found out the hard way when i was rushing to get my car on the dyno the other week, didnt seat 2 of the injectors lower seals properly..result=fuel blowback on boost=one dyno run=$200 wasted=lesson learnt, dont rush:)
I think the lesson learnt here, is when spending so much money on the injectors themselves, is to spend that extra $40ish for a new set of genuine injector o-rings/seats from Nissan.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
