For a normal 550-550whp RB26 twin turbo ( so no point to overrev to 9-10k) What would be the best bang for the buck for a early 90 wo are prone to have oil pump problem ?
I was thinking:
N1 oil pump but I would need to set my rev limiter to 8k...
Standard oil pump with upgraded reimax gears.
ive got a custom oil pump going in mine.. my engine will have a lil more power than urs, ill get the full details when i get to my work pc.
i think for application the jun or tomei one would be sweet buddy.
No point revving the RB26 past peak power @ 6800rpm.
I currenctly have my rev limiter set at 7.4k. I'm just wondering if a N1 pump can take abuse up to 8k SAFELY ? or at 8k this pump is at his max capacity? Like anything.. I prefer to have some ''play'' aka slightly overkill.
N1 is 250 shipped
and I can get a N1 with rebuilted reimax gear for 600 shipped..
Just wondering if I really need to pay 350$ more for a 500-550whp limited at 7.4-8k ?
Sounds like you have a stock bottom end, given you have the older oil drive etc.
Which then would worry me why you'd try to run 370-400rwkw through that bottom end.
Regardless of the oil pump, trying to push that much is going to end in tears regardless of what you do with the pump
Nevermind this issue. One thing at a time. I will be rebuilding my RB26. right now, I'm thinking about the oil pump.
nitto oil pump $1300 same as all the other more expensive jap pumps and yeh ull need a crank collar but if your rebuilding then just get an r33 gtr crank so u dont ned the collar
So why are you buying bigger oil pumps on a small collar now then? IMO thats a more important issue any anything else.
Why not just do the smart thing and peg the power back a bit until you rebuild?
Having the small snout - as i said earlier - makes you more likely to bust stuff regardless of the pump you decide to use.
you could spent upwards of $1700 on a Tomei pump, for nothing!
And it's the reason Nissan clearly changed the design within a matter of years!
So your saying I should only change my crank instead of changing my oil pump ?
I'm saying changing the oil pump is not going to magically save your stock motor @ those power levels and you will still potentially have a failure due to the smaller drive.
Especially trying to pump 400rwkw through it.
If it was 300rwkw, no problem. Most R32 GTR motor owners know they are on borrowed time even @ that power level (for one or another reason).
I wouldn't buy a $$$ pump now, just run the motor till it dies and then follow your rebuild plan.
I understand your point. I was wondering because I saw on a local forum someone selling his N1 pump with reimax gear for 600$ ( and it might be cheaper since i might buy other stuff from him). Considering a reimax kit is worth like 700$+ the pump. I think it's a good deal. It doesn't mean I will be fitting the pump right now. I will when the rebuilt times will come. ( might be next winter, I'm slowly purchasing everything I need).
thanks for your advice.
ur best off just waiting alittle longer and buy new. if i was spending the money to build an engine (which i already have) i wouldnt wana do it half ass and put in second hand parts.
sure it might take a little longer to save and buy but at least u will have piece of mind that your parts wont fail.
do it right the 1st time round
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
