hey guys got a S2 c34 rb25det neo stagea just wonder if anyone has used one of these air intake pipes?? does it fit?? does it look like the pic?? just doesnt look like the hole will line up??
http://cgi.ebay.com.au/ALLOY-INTAKE-PIPE-4...=item255d5b278c
also this one looks like it will fit but its silicon anyone used aftermarket silicon one??
http://cgi.ebay.com.au/SILICON-INTAKE-PIPE...=item483c7049a7
thanks..
Edited by shotpointblank
Hi mate check the diy section or search $5 5 min intake mod. I have a spare intake pipe u can use if need be
thanks..
yeah man ive seen that... i need to change my one anyway, air intake has a split in it or something makes whistlin sounds on boost... but yeah thanks for the opinion..
As long as it is made for a R34 Neo rb25det it will fir and work
The R33 ones are different
I use to use the silicon type.
For the price I would go the alloy one now. Never use to be able to get cheap ones. The only previous ons to the cheap chinese ones use to be made by Apexi at 3 times the price
I had the alloy one. It's not a straight fit...
There is alot of screwing around to make everything fit up properly. Things like the BOV return and oil breather pipe need to be either lengthened or modded. If you still run an AFM, you will also need a smaller pod filter, otherwise it won't fit on the end.
The silicone one is a direct fit and the one to get. $5 intake mod is just as good too.
thanks for the reply guys... yeah gonna get the silicon one i think.. im still using the stock airbox (dont want a pod) but gonna get hks airfilter.. still fit sweet with the box? might just need trimming?
The alloy one will give you problems when the bov releases as the air is too close to the airflow sensor, and its on the wrong angle (air will go up the pipe.)
The silicone one looks better but the bend is pretty tight.
What sort of problem(s) would you get??
Reversion. I get it pretty bad at times, because i have a GCG hi flow. I have minimised it by changing back to a plumb back and using a standard intake pipe (ribs break up the reversion somewhat). It did have a silicon intake but reversion was pretty bad.
I am using the stock S1 silicone inlet pipe with the 5 min. fix. My BOV is in the hot side just out of the turbo and vents back into the stock place in the inlet. How does that fit with the "reversion" syndrome?
it doesn't. using the ebay alloy one with the BOV return where it is could cause false reading on the AFM, when the BOV released the sudden increase in airflow across the hotwire would cause the ecu to dump a load of fuel in the engine. if your using the stock rubber flex, even with the "$5 Intake Mod", you wont experience this.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
