Considering that most oils on the market are not that great to begin with, and the fact that we probably all drive our cars harder than grandmas churcher, you should probably not worry bout the $3 saving you will get from extended interval changes ;)
In other words, keep changing your oil at the recommended interval regardless.
If the oil contamination is much less,why still pursue the same regime?
I have read 20,000km plus for oil changes for those on LPG . I have no experience but I always like to check information from those who have.
Given synthetic oil costs and
oil filter costs ( without labour costs and the inconvenience of finding time to have an oil change) you
could easily be spending an additional $ 350 extra if you
change your oil at 5000k intervals instead of 20,000k.
petrol contamination is only a small part of what happens to your oil while your motor is running... oils lose viscosity over time, cleaning additives stop working and froth up, things like that arent just contamination. i guess heat cycling and running it through a pump constantly must take its toll in some way too. i'd suspect its the people who sell/install lpg that will tell you its a miracle fuel that prolongs service intervals etc
i'm no expert so take what i say with a grain of salt :P
never failed to surprise me how clean the oil stayed in my lpg work falcon . the thing did over 200 kays a day . every week . bout 50 kays a day was offroad in subdivisions. once got to 30-000 over the oil change and it was still clean .
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
