Hi all,
Up for sale is my Bayside Blue R34 GT-R V-Spec II. This car has been modified in a track spec manner... so fully stripped interior, no aircon, no sound system, no sound deadening etc... here's a break down of the mod list:
Engine:
Garrett 2860R -7 turbos
HKS Cam gears (Intake & Exhaust)
Tomei Poncam 260 degree Intake & Exhaust Camshafts
Nismo 600cc injectors
Nismo Fuel Pump
Nismo Fuel Pressure Regulator
Trust Oil Cooler, with oil filter Relocator
Apexi Power intake pod filters
HKS Front Pipe
HKS Cat Converter
Blitz Nur Exhaust
ECU:
Apexi Power FC
Apexi Power FC Boost Control kit (running 1.3bar)
Handling:
Nismo S-Tune Supension
Project Mu HC+ pads front & rear
Project Mu SCR front Disc Rotors
Interior:
Sparco R383 Steering wheel (Suede)
Takata 4-point harness
Fully stripped interior, so no carpet, no sound deadening, no rear seats, no aircon, no cd player etc...
Exterior:
Standard 18 inch Wheels (with Bridgestone Potenza RE-01R tyres)
The car has 84,700 KM's and produces 298kW's @ all 4 wheels (1.3bar).
Price: $49,990 ono
Contact: 0424056507
Email: [email protected]
###PLEASE NOTE### Would be willing to trade with Black Chrysler 300C HEMI with Cash offset
Edited by xanavinismo
https://www.sau.com.au/forums/topic/339786-for-sale-2001-r34-gt-r-v-spec-2/
how much of what has been removed have you still got that can be put back in, is the car still regoed, pics of engine bay and boot aswell
I still have everything that has been pulled out and pretty much everything can still be put back in. Rego expires on January 2011.
I shall upload pics of the engine bay, interior & boot within the next couple of days.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
