are you talking about the small vacuum hose attached to the standard bov? This is the vacuum hose which opens the BOV. By blocking it off, you will be stopping the BOV opening and hence will result in fluttering. Although not sure what damage it could cause? Wouldnt be any different from running with no bov i reckon... Someone confirm this.
actually it's the opposite...without the vacuum feed the BOVs will always be open so it will never boost.
unless OP means...what if I do all that because I am running some other BOV system...in which case just drop off the vacuum line so there is no leak and off you go!
it runs from the intake manifold to the blow off valve, right? that is the intake's way of telling the blow off valve when shit's getting serious and to remain closed.
if you unplug that line i would guess whenever you achieve boost you will hear the bov whistling and releasing your hard earned boost.
don't know how much you know about turbos and how the whole system works but i would also say the wastegate might open a bit later due to the lower pressures in your intake piping from the bov leak. if this happened, your turbo would spool harder so i wouldn't suggest it. you don't know when a turbo will let go.
treat it like a bitchy woman... Treat it nicely and it will continue to blow for years to come ;)
I'll confirm it...you reckoned WRONG....
Like Duncan said...if the bov doesn't get a pressure source when boosting...it creeps open and you lose boost pressure through it...not rocket science here...just common sense....
well put thanks,you have answered that all i wanted to know.
Disconnected mine because I was having issues with something, and yeah, a 300rwkw car turned into a 80rwkw car.
Wouldn't go over 10psi and stalled, and ran like shit.
It is there for a reason.
So no flutterz fully sic bro.
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
