hey guys, i was wondering if a r33 aftermarket turbo exhaust will fit a non-turbo r33. i know the turbos need the dump pipe. i just cant seem to find a non turbo exhaust anywhere. i have looked in the forums and could not find my answer, please help!
yeah it should if its a catback system.
just buy a muffler of your preference then go local exhaust workshop n get. 2.5 inch piping fitted from cat back. i wouldnt go larger than that as na with exhaust with drone.
i have a cannon muffler stainless steel for 50bucks if u want then just buy piping should be like 250 fitted.
the cat back section will fit, but a 3" exhaust on a NA is going to be LOUD!!!! and will reduce low down power. as shorty said above, just go to your local exhaust place and get something made up.
+1
When I bought my non-turbo '33 it had a 3" exhaust on it, and it was VERY loud, which I didn't have a problem with really, but it was more the annoying drone that got to me. I got EPA'd for it eventually and got a 2.5" system made up at an exhaust shop, which brought it down to exactly 90dB (the legal limit)... still fairly loud, but NOTHING like it was, and no drone any more. With the 2.5" setup, it certainly had a lot more low-down grunt than the 3" system, which really only started to pull as you approached the redline and was quite gutless down low... not all that practical!
thanks a lot for the help guys. I'm not sure which way i wanna go with my car either. right now it has complete cream and white suede interior and is sitting on chrome 18s with gold inserts, its a very sexy car. i enjoy the sex spec type of cars :(. i also want to get more power out of it, so i was thing of putting a straight through 3" exhaust with a varex cannon so if i choose to turbo in the future the exhaust is accounted for already. i don't think i can get descend power out of it being NA.
oh it sounds sexy as hell, im sure all the women throw their pantez at ur windscreen!
the chromz must make all the holdens jelous!
on a serious note:
for parts - these come to mind:
nengun
justjap
import monster
or im sure a local exhaust shop could locate something to suit.
btw....wtf is sex spec type of cars?!?
thanks a lot for the help guys. I'm not sure which way i wanna go with my car either. right now it has complete cream and white suede interior and is sitting on chrome 18s with gold inserts, its a very sexy car. i enjoy the sex spec type of cars :D. i also want to get more power out of it, so i was thing of putting a straight through 3" exhaust with a varex cannon so if i choose to turbo in the future the exhaust is accounted for already. i don't think i can get descend power out of it being NA.
Multiple people have mentioned it, so even though you're obviously going to ignore this and do what you think is best anyway, I'm going to repeat myself: a 3" exhaust on a 2.5L NA engine is just TOO BIG... not because of the noise (though it is obnoxiously loud), not because of the "drone" (though it will give your passengers, if not yourself, a headache if driven for a long period of time), but because it moves the efficiency range of the engine too high up the rev range. Just when it starts to peak (as much as it can when NA), you need to change gears.
2.5" is the largest you want to go with NA... some suggest 2.25", but as I've had no experience with this I can't comment - I just know that going from 3" to 2.5" there was a NOTICABLE increase in low-down torque resulting in a much more "driveable" car... less clutch slip and fewer downshifts required as the power was where you needed it.
on a serious note:
nengun
justjap
import monster
all show and no go
http://www.google.com.au/imgres?imgurl=htt...=1t:429,r:4,s:0 perfect example of a sex spec car. not sure if most people would like it, but i saw it cruise through civic (Canberra) and every girl on the strip was starring.
but anyway, i was thinking extractors, 2.5" exhaust (do brands tend to make a difference?) ,larger throttle body and i will have a car will abit of go but much more efficient on petrol and reliable then a turbo r33. i also have a good cai set up.
Re: that car in the pic, all the girls were looking because it appeals to them.... they would like to own/drive that car... not have sex with the person that owned that....
1. You don't need a larger throttle body, if anything will probably make your car less responsive - unless you have over 300rwkw dont worry about it
2. Most n/a cars are less efficient on petrol then turbo cars.... the turbo takes the load off the motor, I realise the turbo puts more air into the motor and you need more fuel with more air, but its better the car is on 3,500 going up a hill with the turbo going then at 5,500 with an n/a.... when I had a n/a i was getting 350km to the tank... when i first turboed the car with everything stock, I was getting 425km to a tank
the reason turbo cars are bad on fuel is because of the way their drivers use it..
3. reliability? maybe a tiny bit... you have one less moving part then the turbo guys, but i dont think that makes a huge difference
have you changed the compression since you have turbo d the car? did you fit it necessary?
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
