Now won't be buying a Garrett turbo in the future , will now look else where ! I hate how companys rely on reputation which once was the best & turn it to shit by trying to make their profit margins bigger ! I feel sorry for the employees which have put their heart & soul into the company , then get treated like a peice of shit ;)
Edited by Tweaky
Disgruntled employee.... What did he expect to happen when they were bought out? Of course there was lots of out sourcing/cost cutting during the "GFC", it also saved the jobs the in the companies that didn't go under, and supported the surrounding industries.
If we think that any other turbo manufacturer is different we're on crack.
could be right with other manufacturers here but,
i thats slightly hypocritial to say GFC and outsourcing and in the same sentence then refer to supporting the surrounding industries? explain that in depth when you're moving jobs offshore for worse quality at half the cost and giving away jobs not saving them.
Edited by PetroDola
Ye posted up here a long time ago, its almost a year old
Original:
http://forums.nasioc.com/forums/showthread.php?t=1936851
SAU link in Feb:
http://www.skylinesaustralia.com/forums/Ga...ll-t309655.html
Pretty much the next "8 months" is now here, there is no decline in product quality at all - lot of hot air about nothing.
i highly doubt that story is true to begin with, msot possibly just one turbo company going at the other, and writing crap, just google the things stated in that statement, cant see anything about caterpillar recalls or ford lawsuits anywhere on the net. all that ever comes up for like 10 pages is that same statement that has spread over like 200+ forums.
only way to check, get someone with a older garrett turbo to measure the front blades and compare to a new one. but i highly doubt their quality can really be that bad, even the cheap ebay nuggets, they do their job pretty well.
compare quality vs price vs performance between hks and garrett and see whats going on, hks turbos are almost double the price, so they better be double as good at minimum.
now i havent compared any tubros one against the other, im just going by whats on paper.
This is only the manufactuer... we still have logistics, wholesale, logistics, retail, sometimes logisitics, the workshop fitting the turbo etc.
I would also say that alot of jobs at Honeywell were saved by this action, yes alot were lost, but because the company did not go belly up, it saved the remaining American jobs.
I still recon the guy took it personally, which if you have put your heart and soul into a company, you would, but just saying, he did.
Original:
SAU link in Feb:
yeah i sensed it was quite old.. just wasnt sure of its legitmacy..good to know though that its more hype than anything.
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
