666DAN Posted October 10, 2010 Share Posted October 10, 2010 Here's a quick guide, will give 100% trouble free perfect installation if the steps are followed to the letter! Let's go! Step (1) - Your parker bulbs have arrived, they may look like any of the following T10 types (depending on what you have ordered) they all share the same feature though, they have a universal T10 base, as found in >95% of cars on the road. Step (2) - Locate you parker bulb socket, rotate the socket so that the socket and bulb assembly are easily accessed. Step (3) - Remove the bulb, it simply pulls out Step (4) - Squeeze the metal tags a bit closer together, this will give a nice tight fit to the LED bulbs when they're installed Step (5) - Now the bulbs are removed, turn the parker lights ON Step (6) - Splay the legs of the LED bulbs at a 45 degree angle, all the bulbs on the right have had this done, compared to the bulbs on the left. This will almost guarantee the metal legs will have perfect contact with the copper tags in the parker bulb socket. Step (7) - Simply place the bulb into the socket, if you have got it the correct way around it will illuminate straight away, if not, simply take the bulb out and place back in turned 180 degrees, it will now light up! If nothing lights up, check that you legs are still angled and that they are making contact in the base, no contact = no power to the bulb. Step (8) - Now everything is working, put the sockets back in their original location, done! Link to comment https://www.sau.com.au/forums/topic/339866-replacing-parker-bulbs-with-led-bulbs/ Share on other sites More sharing options...
HtwCHACtkh Posted September 27, 2011 Share Posted September 27, 2011 Hey Dan, Are LED Parkers bright enough to potentially be used as indicators? If they're orange of course. Link to comment https://www.sau.com.au/forums/topic/339866-replacing-parker-bulbs-with-led-bulbs/#findComment-6035074 Share on other sites More sharing options...
Hadouken Posted September 27, 2011 Share Posted September 27, 2011 Led's are much brighter than normal halogen type bulbs. The dispursement of light is much more direct, (straight). Using it as a indicator light will work because it is not used to disperse the light on to the road but rather draw attention to the blinking. In short yes it will work mate. Link to comment https://www.sau.com.au/forums/topic/339866-replacing-parker-bulbs-with-led-bulbs/#findComment-6035126 Share on other sites More sharing options...
666DAN Posted April 23, 2012 Author Share Posted April 23, 2012 Yes the can be used as indicators......everyone pay close attention to STEP 6, a lot of people think they know better and try to install without bending the legs, this is essential!!!!!!! Otherwise the leg will sit in the recess and do f#@k all Link to comment https://www.sau.com.au/forums/topic/339866-replacing-parker-bulbs-with-led-bulbs/#findComment-6328379 Share on other sites More sharing options...
