Hi everyone,
Last year at a car show we got our R33 dynoed with the following mods,
hks bov, cat back 3" fujitsubo exhaust system, turbo smart boost controller (red one), blitz sus pod filter and 12 psi on stock turbo, ecu and intercooler.
At that time we had the problem of a miss fire because of the spark plugs not gaped to .7 so it was missing on the dyno but we still got
162rwkw on a hot day. we also had a slipping clutch
Tomorrow were taking it in again on the same dyno to see what we have gained.
the list below are the mods that we have added to the top.
Heavy duty clutch, 3" dump pipe, FMIC, high flow cat, 14psi of boost. - we have reset the ecu after installing all of these mods.
i'll post the dyno graphs tomorrow.
What do you guys/girls expect i would get with these new mods ?
https://www.sau.com.au/forums/topic/33987-r33-gts-t-dyno-graph/
I think you would be doing well to get 180+ rwkw (241rwhp)
Different dyno's will give different readouts (as I have found out over the last 18mths).
Edit: '95 S1 w/ 85,000km.
For me (in order):
(Unigroup)
* FMIC
* HKS Pod
* Daiken Exedy Organic Sports Clutch
* Nismo Cat-back
* 12psi
* Stock Turbo
* Stock ECU
= 192rwkw (257rwhp)
(Unigroup)
* FMIC
* HKS Pod
* Custom 3" Front/dump + 3" Cat
* Nismo Cat-back
* 12psi
* Stock Turbo
* Stock ECU
= 203rwkw (272rwhp)
(Unknown at Western Sydney)
* FMIC
* HKS Pod
* Nismo Cat-back
* 12psi
* Stock Turbo
* Stock ECU
= 186rwkw (249rwhp)
(Croydon Racing Development)
* FMIC
* HKS Pod
* Nismo Cat-back
* Bosch 040 Fuel Pump
* 12psi
* Stock Turbo
* Stock ECU
= 180rwkw (241rwhp)
So as you can see different dyno's and different days (the above UniGroup days were both 30+) certainly make a difference. I certainly noticed a "seat of the pants difference" between #1 and #2 and also #3 and #4 (no mods were done between #2 and #3) but the Dyno's didn't show this.
As Benm was saying, it's too hard to 'guess' what power your going to get cause every dyno is different.
The important thing is that you get a gain.
I would take your old dyno print out along when you do the new run and then compare the two graphs (as long as it's done on the same dyno).
Just as a comparison (for what it's worth), mine has pretty much the same mods as yours but at 12psi and did a 169rwkw.
Again, it's all about getting a gain on the last run, and also, outright power isn't everything. I only gained about 10rwkw at maximum power, but I managed to get rid of the flat spot in the mid range. Getting rid of that gained me about 34rwkw in the mid range !!!
J
Hey just got back from the dyno and it was done on the same dyno as last time (shoot-out mode).
I'll post the graph tonight.
We got a max of 184.5rwkw's (247.4hp at rear wheels) on the last run. that was with some more boost. but the a/f ratios were going stupid.
With the last run we were running 14.5psi which the a/f ratios were leaning right out to 30.0 which isent good. but on 12psi we got a/f ratios of 12.4 so we left the boost on 12 intill we can get bigger fuel pump and injectors. if thats the problem?
We are pretty happy with the results going from 162rwkw's to 184.5 rwkw's just in (front mount, 3" dumpie.) and in a month or 2 were gonig to bolt on a bigger turbo and do fuel pump and so on and chuck it back on the dyno ;)
we noting trying for power we were just seing what the difference in mods made to the car.
unfortunaly we live 4hr's away from the nearest track so its not every week we can make it out their.
with the first list of mods in my first post (with out the miss firing as we fixed it) we got a 14.1 pass on the quarter at 103mph on street tires. but we had a really really bad slipping clutch.
So were going to take it down again next month and see what the outcome is. were hoping for a high 13 or better ;)
i wouldnt put on the turbo yet, id concertrate on upping the torque low down, do the turbo later, check out some of syneykid's posts on what else you can do before the turbo
i wouldnt run 14psi without some form of fuel control, even without an safc, probably 12psi max
your just asking for shit to go bang :cheers: - this explains why yours a/f's = psycho
just cos you are seeing more power at 14psi doesnt mean its good power, probably doing damage than good
you'll probably loose power adding more boost as the ecu corrects the timing and stuff so it doesn't go bang.
im no expert but this is what i've learnt anyway
agreed that dyno figures can be somewhat misleading but i believe you can get a rough estimate from a dyno graph, and thus, they are a tuning tool - i wouldnt class them as being an accurate reader of power.
comments about track times are abit more valid however i wanted to say that an ET is sometimes pointless aswell. the best indicator of power is the terminal speed.
fwiw, i have recorded a 199.5rwkw on c&v's dynodynamics dyno. ran a 13.8s ET with a 2.1sec 60ft and 99mph terminal speed. goes to show that the car was tuned for mid-range...
mods are as follows:
-powerfc
-avcr @ 0.8bar
-fmic
-full exhaust
-stock airbox with hiflow air filter
    • I think the consensus was that's normal. Sloped road surfaces or something? I remember @silviaz went through this before. It might be one of those things you never notice until you pay attention to it.
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
