Rule 1 of Fang Artists: Don't talk about Fang Artists
Rule 2 of Fang Artists: See rule 1.
Apparently word has it that back in the day, they all had sweet rides. That is until most of them grew up and had families.
They still do the occasional Sunday lunch together and go to garden shows when time permits.
Haha, old skool :D Go the fanga's!! :mrt:
  • Replies 165
Clive, yours is the last entry i received, came through at 956 this evening. No other emails from you sorry.
Entries are closed. List is updated.
yep, resent it then after re-reading the first post and noticing the "*** Also, if you are mailing you entry" etc and knowing I didn't rename my attachment that way and guessing it was discarded.
new regulation I didn't see my bad luck I suppose.
Na mate, we didn't receive anything at all. The renaming was just a request so I didn't have to rename 60 files, I still accepted them. Only 1 email came from your address.
Thankyou Ryan, for the schedule and continued hard work with setting up these events.
Chicago looks great! Have been hanging out for a layout which had some good chicane action :whistling:
When are you ready to start accepting grouping requests?
need to learn the map now...cant wait for this to happen....also if one of the competitors wants to become a passenger, do they still have to fill the passengers disclaimers form?
Nope, your entry form covers that, I know cos I asked last time.
I like the first skidpan layout! Looks like a lot of sideway action.
The battles look like they'd favour high powered cars, get your handbrake turn right then put the power down.
THANKS!!! the way the course looks like ill be last for all of them...its my first ever trying to push the car in this way instead of just letting it rev out in a straight line...nervous and excited..wud luv to get pointers of some guys here of how to drive the car on the track properly...n thats y i am coming..to learn...yay...cant wait...
Two ways to drive AWD @ DECA:
- Slow in, fast out, smooth.
- Fast in, feint and/or handbrake, chucking her like a $1 whore.
hahaha...never done it...but cant wait to do it either...thnx for the tip...bnow just have to put the words into action...:P
Oh you Fu(kers.
I miss one and big red is there! Bugger!!!
And Ash, he's more of an amusement stand style attraction than anything else haha
Might have to come down and help out-I'll try and fit it in :P
Thanks, Leon helped me with this one. He will doing a lot more next year :P
damn.... look at the battles...
The only reason they look hard is because of the way they are drawn. They are not hard to remember once you go over it a few times.
Oh you Fu(kers.
There is no big red.
Two things also:
1) Please PM me your PREFFERED groupings. No guarantees.
2) VOLUNTEERS are needed!!! And while we appreciate drivers helping we still need dedicated volunteers! Drivers breifing wont happen unless this is all sorted. hence why we try to sort this out before hand.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
