It's time to part with my old pride and joy, was hoping to do something with her before the Registration ran out but I've been too busy enjoying the Nissan Stagea.
Car is available for sighting most weekends, sms or give me a call and I will confirm availability. Car is currently in Blacktown, will advise address when confirming via phone.
I need to provide a ballpark figure but please, I'm open to offers as I need to get this car off the front lawn :P
Asking Price: $1000 ONO (as above, please come and check the car out and make a reasonable offer) - I will not part this car, ONLY to be sold as whole.
Rego: As mentioned in the topic the car was due for registration in February, due to lack of finances it never happened and now the car will require a blue slip. Note that the plates will not be on the car upon collection.
Distance Travelled: Estimated at around 280,000km's, the guage stopped working a while ago but may be repairable. It hasn't been looked at yet.
Fuel: This car is dual fuel (LPG/Petrol), the LPG system has a small leak in the engine bay due to a back fire, requires a new gasket/sealant and the LPG will be running fine.
Airbox: Is damaged due to above mentioned back fire, blew the plastic brackets off.
Rust: 4 area's that I'm aware of, a small bit on the strut tower in the engine bay, inside drivers door jam, outside of drivers door (underneath where the plastic strip was), left hand upper inside of bootlid (right near the back of the boot).
Brakes: Back pads are due for replacement, not sure on the condition of the rotors.
Exhaust: Everything ok except for several small holes in the rear muffler.
Tyres: Due for replacement, currently running 215x17
Suspension: Lowered springs & heavy duty shocks
Security: Fitted with an imobilizer/alarm (central locking works on all doors except the rear passenger side, I think the cable has become disconnected from the locking mechanism)
I will add to this thread when I get further time, I'm sure there are things I have forgotten to add. If you have any queries though feel free to ask your questions in the thread and I will answer.
For weekend viewing contact Stephen on 0438 242 573.
https://www.sau.com.au/forums/topic/339900-1989-gxe30-skyline/
Forgot to mention it has an RB30, which all of you probably knew anyway.
It also has some hail damage, major dents which should be a lot easier to get out as apposed to the mess little hail leaves behind. Remember that huge hail storm that hit Blacktown 2 or so years ago.. it was like the holocaust.
I would have taken more pictures this weekend but unfortunately I was busy taking pictures of my written off M35 Stagea instead.
Cheers
This could be the last addition to the thread, the poor girl will probably go to the wrecker's this weekend or next weekend.
So if anyone is interested in having a look at the car, please sms as soon as possible, or send a PM on here.
  • 3 weeks later...
Car has now sadly been towed away, if anyone wants anything off it, it has gone to pick 'n payless Blacktown.
*thread closed*
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
