Hi all,
Givent the amount of airbox vs pod threads on here I thought I might share my experience.
My car is no power house, it is a S2 r33 gts-t with a turbo back exhaust, r34 gt-t intercooler and until now a K&N pod.
The reason I love this car is its responsiveness which is why I have kept the mods to a minimum. I enjoy its peaky style compared to my old pushrod v8.
Now I have finally sourced an airbox, bought myself a BMC filter and installed it. I also made a scoop which ducts air from behind the grill into the snorkle (figured it might be worth a few kw at road speed?)
Now I have noticed lately as the weather has warmed up that my car has become less responsive when leaving the lights (fast or slow) no doubt due to the fact that the pod/engine bay had heat soaked while sitting still. I also noticed when cruising slowly that if you put your foot down (rolling start) that it was not performing that well and even hesitated sometimes.
So I have finally sourced all these parts and put them in, what a difference!!
The car is sooooo much more responsive now, I dont think it makes any more peak power but in any circumstance when you accelerate, standing still or in gear its better! the car also dosnt hesitate anymore.
This was probably the best 'mod' I have done to the car and will be a great thing next time/if I get pulled over :D
Anyone 'deciding' which way to go with the pod vs airbox debate should read this carefully before selling their airbox I think :)
to make sure I wasnt making the improvemtn up in my head I gave dad the keys (he is a car nut himself) and even leaving the court he noticed a difference, once I told him what I had done he was quite shocked it was so difference from just that mod.
airbox and high flow filter FTW!
Anything to reduce heatsoak is going to be a win. I still have my shitty foam mushroom pod filter on my 33, but have purchased a fibreglass cold air box to enclose it off a fellow SAU member here in Canberra. He had also lined the inside of it with that heat reflective shiny foam shit to help....and it definitely makes a difference. My pod used to feel hot to the touch after driving before, and now it's barely warm.
ill get some. basically just some folded aluminium which mounts with the same screws that hold the snorkle to the rad support. it bents down with a curve behind the grill so it scoops incomming air up into the snorkle. dont know how much it helps but it certainly cant hurt!
It's not the pod's fault that you just stuck it in a hot engine bay! biggrin.gif
Most people who install pod filters fit some kind of heat sheild and/or cold air intake to work around this issue.
In saying that though I've heard that the stock airbox with a good quality filter is good for up to 300rwkw and is much less bother with the cops!
Personally I love the sound of the intake with the pod filter (I am running an Apexi pod in a fully enclosed UAS aluminium cold air intake box)
+1 ^
I made my own heatshield/box out of 5mm aluminium and lined the inside with insulation material; there is no noticeable difference between driving when it's cold or driving when it's hot. Obviously when ambient air temperatures get hot enough you notice a bit of reduced throttle response, but panel filters would feel the same effect.
It's well known that pod filters will be less effective if they are exposed to the heat from the engine bay. Simply box it, problem solved.
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
