  • Replies 106
jangles it better be the the fresh datsun, pull ur finger out.
Damo wots happening with ur drifter at the moment? how come its not running?
had an issue with the head. its always been a problem but only discovered it after a few chnages made during the rebuild. pulled the head off. fix the problem but havent put it back together yet, mainly because i wanted to put it back together and add a big turbo.
ive just started work on it again after not toutching it for 2-3 months. a lot of work ahead of me again.
I just need to sort out a bottom end it will be there
i hope to see it out there rob you have missed far to many even for my liking.
https://www.sau.com.au/forums/topic/339948-powercruise/#findComment-5491059
LOL at all the broken RB's :) .
Should be there, pretty keen to link from the back straight onto the start finish straight again!
Ben
I'm keen to see that!
Damo, so are u adding a bigger turbo then? and wot is it? or surprise??
https://www.sau.com.au/forums/topic/339948-powercruise/#findComment-5492287
yep its a bigger one. nothing special just the usual garret rubbish but i wont be putting any big numbers in it just yet. 260+ at this stage and then e85 later on. main concern is doing evrything right once so i wont be spending every night working on it next year.
https://www.sau.com.au/forums/topic/339948-powercruise/#findComment-5492767
something in a RB30 block...
hmmm dont think i can help with a 30. i got a complete 25 bottom end sitting in my garage thats all.
lol yer im dying my my 3 litre to be running. engine done. just gotta save for bolt ons really.
https://www.sau.com.au/forums/topic/339948-powercruise/#findComment-5492961
I need a 30 crank or will go with one of the stroker kits. 3.4 would be nice but then the T51 might be a little small. :)
Ive missed every powercruise so far. So Im not getting my hopes up this time as I got other things on the go. Like my new house :-)
Edited by WHITER33GTS-T
https://www.sau.com.au/forums/topic/339948-powercruise/#findComment-5493309
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
    • Thanks, these seem to lay it out a bit differently. I will get back to you guys after i do some tests and more digging.
