  • Replies 106
haha i can't exactly borrow them cause i intend to smoke the tyres off them! but im all set now anyway, pit lane garage too with jangles, gonna be great.
and gtr blondie i call everyone mate haha boy or girl
Pit lane hey! Score! I'll make sure to drop in and say hi. Too scared to put mine in :P
What's up with the GTR Damo ?
we think its gunna be ok, ever since the car was repaired the clutch fan hasnt been right, replaced it with a secondhand one and put a spacer there to clear the belts but... its still not running 100% true and we are slightly concerned about the water pump. I have tested it and cracked some decent speeds and some 6k launches but just not 100% happy, Im still taking her down :thumbsup:
yea right. a bloke i know mid last year had a brand new water pump fail after about 3 hours. the result was a fan throught a radiator and a very big repair bill. lckily the suplier of said faulty pump paid for a new water pump. new ally radiator and a thermo fan setup but i think the bloke was out of pocket for the labour.
take the fan off and run decent thermos. i know every one says they dont work but if you get AU falcon or twin VT commo fans they will definatly do the trick.
    • Definitely the stroker kit. once you mention you have a RB28 everyone will assume you will flog them and hopefully won't start asking about support mods. Anyone will be too scared to race you, except maybe the RB30 boys
    • Just a quick update: I decided to go ahead with the de-cat for now. The exhaust shop inspected the catalytic converter and said it was in good condition. I took a look myself, and it does not appear broken nor clogged. After the de-cat, the car feels more responsive and smoother. The shop also reinstalled the exhaust temperature sensor into the de-cat pipe, and now the warning light no longer comes on, even when driving hard. The only thing that’s bugging me is the tinny, “can-like” sound the exhaust makes now (similar to having a hole in the muffler). The shop suggested that I might need to replace the muffler. I'll have to think on what to do next.
    • I want to start upgrading but don't have the budget to drop 15k at once, if i was to do one first which would be better and why?
    • Yuh. It is very rare for a single turbo to throw ceramic into the engine. Quite common on GTRs. As I posted above. Mine did destroy the O2 sensor on the way out though! Plastic compressor is fine with the temperature. It's not some flimsy PE/PET/PP thermoplastic. It's a thermoset resin with reinforcing material in it (a composite, as posted by @Lithium above). The compressor never sees much more than 100°C because it's never boosting very high. If you boost it high enough to make a lot of temperature, then the turbine will depart the scene and stop the party anyway.
    • From what I understand, it's a ceramic turbine and a plastic compressor (not sure how it doesn't melt then lol) I heard the series 2 r34 gtt has a metal turbine but I doubt that. @GTSBoy When you blew your standard neo turbo it didn't cause damage from memory just the turbine ended up in the cat?
