Hi Guys,
so i just bought a skyline v35 from trader who advised me that i can use the
Shell Unleaded E10 fuel type.
does anybody here recommend this? the fuel cap says 'premium unleaded only'
and the shell website says 'shell Unleaded E10 has a minimum 94 octane rating'
is this ok? i don't know much about this stuff but hopefully you guys can help!
cheers!
https://www.sau.com.au/forums/topic/339952-shell-unleaded-e10/
No I would certainly not use it. I would only use 98 octane fuels.
On the shell website it also says:
If your vehicle manufacturer recommends a minimum 95 octane then Shell V-Power may be a more suitable fuel.
If they dont recommend it for cars that recommend 95 octane, I certainly wouldnt use it on cars that recommend 98 octane fuel.
Also, my experience using the old 100 octane shell fuel which also contained 10% ethanol was it got considerably worse fuel economy until you had it tuned for it.
well i'm currently using 95 octane cos its premium unleaded? i guess i'll keep to it..
E10 has up to 10% ethanol in it.
Unless your fuel system is designed to cope with it, dont use it. It chews away at rubber and plastic within the fuel systems.
As above.. not a good idea.
so just to clarify 95 octane is (at a minimum) the right fuel for me? lol i think i'm willingly confusing myself..
Hmm I thought all those myths had been put to rest. How many people are running E85 (85% ethanol) on this and other forums without issues with factory fuel lines etc??
No I think 98 octane is at minimum the right fuel for you. I would never use any less. Japan has 100 octane fuel.
Thats a myth. I've run 20% Toluene, many other additives. Not a single problem.
As for the OP, Id find a service station with BP98, Shell 98, or Caltex 98. They may cost you a few dollars more, but I bet you go more kms too.
For how long?
I know personally of race cars who have left ethanol fuels in their rubber fuel bladders and fuel lines for a couple of weeks between events and have chewed through standard fiel lines.
This is just my personal experience.. other people may have different experiences.
Edited by GTS4WD
well are there any adverse effects from pumping 95 octane fuel? cos i've been using that for a while now...and is it ok to mix 95 and 98..?
For how long?
dude, it's a myth. my car ran on E85 for about 18months straight, also didn't get driven for weeks at a time as well. Car still in perfect health.
if you're talking say a 1985 car or something like that, perhaps, but really any of our cars will be fine.
I noticed this and I asked the local Shell about it. They told me their E10 is only rated at 94 octane minimum. United E10 which I normally run in the daily is the same price (if not slightly cheaper) and is minimum 95 octane.
How do you find the E10, do you get worse fuel consumption? or is it tuned for it?
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
