You've pretty much answered your own Q, jnr.
Armed with a multimeter:
IGN will be bat. voltage
SIG will fluctuate according to airflow i.e. RPM
GND will short to the chassis.
should be easy to map the loom with your stock sensor.
Unless I have no idea WTF...
Hope that helps.
https://www.sau.com.au/forums/topic/34000-q45-afm-rb20-afm/#findComment-681591
Still unsure about this one cos that diagram actully shows an extra "signal ground" does that have to be joined to the Q45 GND, would they be the same. In that diagram the look different ... ????
Ok the RB20 wires are:
Black with silver flashing - Earth
Orange/Blue - Signal Wire
Black/White - 12V Power
Blue/White - ECU Earth
One ground is thru the ECU the other direct to the chassis. At the moment as im using a Series II R33 AFM i only have the ECU earth wire connected, meaning the black with silver flashing wire is NOT connected to anything.
Do you know what the spades on the Q45 equate to?
https://www.sau.com.au/forums/topic/34000-q45-afm-rb20-afm/#findComment-684729
Sorry: dumb question.. but with is the Q45 AFM ? Are you using this as a substitute for the Z32 AFM ? How much? I can do some rewiring if it comes to Z32 AFM time.. ~$300 for an AFM seems a little rich for a bit of plastic and a heat resistor..
https://www.sau.com.au/forums/topic/34000-q45-afm-rb20-afm/#findComment-684966
Well if there is only 3 wires on the Q45 AFM then it is like the RB25 Series II AFM which aslo only has 3 wires.
You can be pretty sure (It is on my R32 RB20DET...can check with a multimeter) that the :
- black/white is 12V power,
- the orange/blue is the signal wire,
- blue white ECU earth
...and just leave the black with silver flashing.
https://www.sau.com.au/forums/topic/34000-q45-afm-rb20-afm/#findComment-685153
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
