hey everyone
does anyone know if BMW E36 M3 mirrors fit an r33 gtst series II.
or know if u can (and where) get mirrors with indicators in them that will fit.
thanks :D
https://www.sau.com.au/forums/topic/340035-mirrors-and-indicators-in-one-unit/
Ebay, you can get universal mirrors with indicators just a matter of making an adaptor plate (or buying one) and fitting them up and wiring them in. Bare in mind most have LED's in them so you will need to wire in a resistor otherwise your indicators will flash fast cause it thinks you have a blown bulb
Pretty sure Ganador make them with indicators for your model, go genuine, you won't be dissapointed.
i have ganadors and there awesome, but they r small, u definately notice that there half the size of the stockies. mines make them for r34 with indicators as well so maybe r33 too. but there f**king expensive as
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
