1996 R33 GTST - Series 2
The engine has been rebuilt in the past two months due to new turbo (ATR43). New engine has only done about 2000 kms.
The engine has forged ARIAS pistons, metal head gasket, all brand new belts including timing belt and new water pump.
The new turbo has done around 5000kms.
The car also has the following:
#All four Tein Suspension
#Genuine HKS intercooler
#K&N Pod Filter
#GReddy Profec B-Spec2 Boost Controller
#APEXi Power FC & Hand Controller
#3inch turbo back exhaust which goes into a 3inch high flow cat and that goes into a 3 1/2 inch genuine HKS super dragger
#Turbo smart blow off valve
# ATR43 TURBO
#Remote start/window lift kit
The car is pushing on low boost 200rwkw. On high boost it is pushing 260rwkw. I have the dyno charts for the car.
Things for road worthy - if brought without out one.
#Remove pod filter and replace with standard airbox
#Remove blowoff value and replace with standard
#unplug the hand controller from the power FC
Car in excellant condition. I currently have a company car and have not drive the skyline as much as i would have liked.
about $13,000.00 has been spent on the car in the last 2 years. all work that has been done has reciepts and will provided to buyer.
$17,000.00 ono $15,000.00 with no road worthy cert
Contact: Koosh - 0409 408 990
https://www.sau.com.au/forums/topic/340110-1996-r33-gtst-series-2/
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
