Hey guys,
well time has come to sell my r32 gtr :)
i have owned it for just over a year and has been a great car...but am needing a more practial car as i am doing a few more kms these days so has to go.
it has been resprayed in N1 silver which is same as the pewter of the s15/r34's and pretty sure there is only 2 in aus this colour!
it has had a power run at RE customs dyno night and made 275awkw's. havent done a run with the adjustable cam gears yet.
anyway heres a run down of parts/mods:
It was imported in 07 and im the 3rd owner of it in Aus...
1994 R32 GTR RB26DETT
126XXXkms
Performance/Engine:
Engine Rebuilt but unsure of internals except for HKS Metal Head Gasket
N1 Turbo's
HKS Hard Piping Kit (turbos to plenum)
HKS Mushroom Filters
HKS Intake Piping
HKS Split Dump Pipes
HKS Front Pipes
Greddy Adjustable Cam Gears
Gates Racing Timing Belt
Apexi N1 Pro Exhaust
De-cat
Apexi Power FC and Hand Controller
NISMO Fuel Pump
NISMO Adjustable Fuel Reg
NISMO 600cc Injectors
GReddy Profec I EBC 14psi - Low....20psi - High
Blitz Oil Cooler and Remote Oil Filter
GReddy Air Diversion Plate
Visual/External:
Re-sprayed in R34 GTR N1 Silver
Bomex Side Mirrors
NISMO Carbon Boot Lip
Fibre Glass Bonnet (Trust i think)
N1 Style Side Skirts
Trust Style Rear Pods
Tinted windows
N1 Headlights
Interior/Internal:
Driver and Passenger RECARO Seats
NISMO Gear Knob
Apexi EL2 Boost Gauge
Apexi EL2 Water Temp Gauge
Apexi Gauge Control Unit
MOMO Steering Wheel
GReddy Auto Timer II
In-Car Entertainment:
Pioneer Head Unit
Soundstream 6.5" Front Speakers
Soundstream 6x9" Rear Speakers
Pioneer 600w 4 Channel Amp
Alpine 600w Mono Amp
Alpine 12" Type R Sub
Braking, Driveline, Suspension & Handling:
VOLK TE37's Resprayed Black 17x9.5+12 Fronts 17x10~+18
Falken Rt-615 Semi Slicks 255/40/17
CUSCO Castor Rod's
Alloy Subframe Bushes
GReddy Type S Coilovers
Alloy Steering Wheel Bush
NISMO Front Strut Brace
Cusco Rear Strut Brace
NISMO Braided Clutch Line
NISMO Big Slave Cylinder
Braided Brake Lines
HICAS Removed and Lock Bar Installed
NISMO 2 way Rear Diff
Blitz Active Twin Plate Clutch
Blue Rays Duralinium Wheel Nuts
Cusco Rear Sway Bar
i have serviced it every 5000kms with Motul X-cess 5w40 and changed spark plugs and fuel filter as well.
has new brake fluid, coolant and just changed transfer case fluid and gear box oil (redline light weight shockproof)
comes with Rego till April 2011 but no roadworthy at this stage. (maybe at the right price i can arrange one)
here are a few pics i have taken...will get more asap
PRICE: 24,000ono Offers welcome but nothing stupid, lots of quality parts on this car
Located eastern suburbs melbourne, Ringwood/Croydon area can also be viewed western suburbs st albans area by arrangment.
Contact me via pm anytime or 0422183152...between 8am-5.30pm please text msg as i have work monday to friday.
cheers kieran
https://www.sau.com.au/forums/topic/340114-n1-silver-94-bnr32-gtr/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
