Yep , in the series 1's only the 260rs had hicas. On the S2's the factory manual stagea's also had it. Are you sure the movement is in the rod ends and not play on the rack gear itself? Do both wheels move at the same time or can you rattle one around without the other one moving.
Almost certain it ain't in the steering rack. Can move one wheel at a time. At work for next two days, will check it out in more detail on Friday.
  • 9 months later...
