Hey All. Silver 93' R33 Skyline GTS-t M-Spec. Rego: ACT YDO-32P. 148,000 Km's.
I tired selling my car earlier this year, but i wasn't really serious about it. Now I am serious about it. Have just bought a 2nd house and unfortunately now its time for my baby to go. It serves currently as my daily driver and is always garaged and serviced every 5000 - 7000km's. Have just fitted new Front and Rear brake pads and will service the car again in the coming couple of weeks. Mechanically the car is great and has been ridiculously reliable over the entire 7 years I've owned it. Mods include:
Engine:
Full 3" Turbo back exhaust (Titanium from cat back!)
Nismo FMIC
HKS Super Sequential BOV
Blitz Airpod
Oil Catch Can
JJR Coilpacks
Chipped ECU
Suspension:
HSD type HR Coilovers
Front Sturt brace
Lower Control Arms
Tie Rod Ends
Whiteline Sway Bars
All Bushes Upgraded
HICAS Lockout Bar
Brakes:
DBA 4000 Slotted Rotors
Bendix Ultimate Pads (New front and rear pads fitted 4/10/2010)
Stainless Steel Braided Brake Lines
Front calipers repainted red
Motul RBF 600 Fluid
Custom Front Brake Air Ducting
Drivetrain:
Kaaz 1.5 way Mech LSD
JJR Single Plate Ceramic Button Clutch
Wheels:
17" Blitz R Racing Wheels
Exterior:
Nismo Front Bar
400R Side Skirts
Adjustable GTR rear wing
Full Nismo decals
Nismo Clear Side Indicators
Interior:
Bride Bucket Racing Seats
Custom Rear Parcel Shelf
Panasonic Head Unit
Pioneer 4-way speakers
A-Pillar Mounted Boost Gauge
Oil Temp Gauge
White Dials
Momo Gear Knob
Apexi Turbo Timer
The car was last dyno'd with 209rwKw @ 11 PSI. It is running the Mines ECU (or atleast a piggybacked ECU) which gives 12:1 AFR's no matter what boost you run. Will do 1.09's around Wakefield Park with the old Federal 595 RS street tyre. All the suspension componets are adjustable. The rear parcel shelf has 2 trap doors in it so you are able to access the top of the rear struts so you can adjust the rear damper. The car is fantastic for all driving types and will impress when pushed.
A couple of things to note is the passenger side skirt has some minor damage (pictured). It is cracked in a few places and I no longer have the funds to fix it. To compensate for this, a set of 17” Volk rims (pictured) will be sold with the car for no extra price. Also the passenger seat has a couple of wear marks on the bolsters (pictured) and the drivers door interior is cracked wear the drivers elbow sits.
Asking $11,000 on Car Sales but for fellow SAUer's I'll do for $9,000 firm. I know you can get newer ones for less money, but this is as close to a unique R33 as you'll get!
No Joy riders or Test pilots please. Located in ACT. Contact Luke on 0438 481 354 or PM here...
Free bump mate, i remember seeing this car at Wakefield not so long ago, it was super quick around there thats for sure. Lots of mods for the price, tip top value!
Good luck with the sale. Cheers.
Car will be completely serviced tomorrow including new diff oil and cooling system flush.
Is no one interested? Seriously, this car is a real surprise package. It will and has put more highly rated cars (GTR's, EVO's etc..) to shame around Wakefield Park. Its great fun punching above your weight! The car is unbelievebly reliable and has never missed a beat the entire 7 years I've owned it. Reliability was one of the requirements i had in mind when i built it, thus only the basic power mods and with regular servicing and up-keep, this car is mechanically sound and i am very confident it will keep going for many years to come...
i may also possibly consider swaps for near standard cars of less value with a cash adjustment my way. something like a stock Skyline or similar would be ideal but im open to others. make an offer and see how you go...
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
