hey i have a r32 with and rb20det 5spd and im having over fueling issues, well i was ......
my standard ecu was over fueling under 14psi of boost and didnt really bother me n after u give it a flog you could smell petrol and i thought who cares at least its not running lean.
but then i bought a re-tuned kaikimoto ecu that re tuned fuel and ignition timing and took of speed limiter etc. so plugged it in and took it for a drive and it wasnt over fueling and seemed the same or slightly less then standard ecu.
thought that was weird a standard computer doing that, has anyone encountered this problem before?
mods to my car are 3inch exhaust,fmic, hks air pod filter, 14psi. (ecu tuned for these mods)
had standard spark plugs so replaced with irridiums and same result.
thinking of putting standard ecu back in as i dont know if re tuned ecu is making it too lean or not
any help would be great
https://www.sau.com.au/forums/topic/340156-rb20det-overfueling/
the standard ecu is tuned to be rather rich. this is safer than a leaner ecu and is better for a more universal use. it allows a bit of head room for if the fuel filter gets a bit blocked, injectors get a bit fouled or the fuel pump plays up.
if the ecu wasn't retuned whilst fitted to your car it won't be much better than the stock ecu, even if it was tuned for a car with the same mods.
the best thing to do is to put the car on a dyno and get them to check the AFR's. it will tell you how rich it is running. if it isn't that rich but you still have a fuel smell, then it could be that your cat converter is shot (empty) and this often increases the amount of fuel smell you get.
i have the same issue, very strong fuel smell after just moderate acceleration, even just dailying i get fuel smell, running 8 pound, stock everything, apart from zorst, fmic and splitfires, my cat is new so its not the problem as mentioned above, the only thing i can put it down to is a fuel leak in the engine bay and a bad one at that, but i cant seem to find any issues in the lines anywhere and my fuel usage is normal, it has a new fuel filter and ive checked the lines to it to.
:S
hey thanks, i just went back to stock ecu to be safe cause of running 14psi. however before i did this i wanted to see if the ecu was really chipped and speed limiter was removed so tryed going over 180 and nope it had limiter n hit the limiter twice and now its playing up. went back to standard ecu and same issue occurs.
when you get on boost flat throttle at about 4-5grand all way to redline it makes rapid misfire type sounds and bogs down?
could the ecu have done something or does it sound completely different
sitting on the limiter possibly fouled up the plugs or overheated the coils. try a new set of plugs and see what happens
also, there is an easier, more legal way to see if the ecu has been chipped. you can usually tell just by opening it up.
kool, i'll try that.
didnt want to open it because it has wax seal things holding the covers on and didnt want to break the seal incase i needed to refund it.
i really hope its spark plugs
was spark plugs the iridiums blew up haha surprised it still idoled the gaps were like 2 or 3 mm haha
cheers for the help
    • This is a real nostalgia trip for me, I mean SK Bilsteins? I ran those lol Good times.  Good work Duncan, it's not an easy job in many respects. I'm sure the family appreciates it.
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
