Should have had the intake pipe go into an empty airbox in the standard position and from there to go back to the turbo. a mate of mine had this setup on his BMW and had the pipe go into his stock airbox which his BOV was inside aswell :P Not once did he get caught either.
  • Replies 206
Guess i'll have to get new injectors when i do more performance. which i'll remind everyone won't be for quite a while.
How many people would be interested to see the difference in power output when i put the new box in? cause i'll be getting it retuned when i do it, so i guess i might as well put the dyno sheets up.
ca 18 375cc injectors, all cleaned and flow tested.
As far as i know they should be suffiecent enough to handle the power i want to get out of the car.
Whats your car putting to the wheels?
R33 ones are 370cc from what I know and they max out around 210-220kw.
Oh, need to ask this, at the moment i don't have a BOV, when i back off on the boost, i get a flutter sound, is that bad for the turbo?
And seeing as im staying auto, do i need a bov with my setup? Seeing as when the gears change i don't need to back off the accelerator and i'm still on boost for the entire next gear, will putting in a bov ruin that continuous effect?
If i need a bov, i want one that doesn't make much sound when im driving around normally, i dont mind if it makes noise when i've been booting it, but still the more discrete the better. I like the sequential bov's, if that what there called.
no its not bad for the turbo, but a recirc makes tuning slightly easier and will make it a lot quieter if that is what you are after, atmo venting will just be even louder and more annoying.
if you get anything adapt a recirc bov into the intake.
fit a std BOV and it will clear the issues of flutter
the BOV only fires when you close the throttle body so it wont affect the throttle body always on (auto gearbox style)
imho fit a bov
nissan made it std for a good reason
only thing is standard manifolds etc have no provisions for a stock bov, might be easier to fit an aftermarket one with a plumback attachment. I know the rb30et didn't come with a bov from the factory either.
It isn't a huge issue, just comes down to noise and making it easier to tune on gearshifts.
when i get the new gearbox put in i'll tell my mechanic to put in a recirc bov at the same time. Then we'll see what difference that makes on the retune.
Oh and i was just talking to the mechanic and he recons the injectors should be good for about 250rwkw. The limiting component is my gearbox at the moment. So we shall see what happens later down the track.
cheers
Kurt
Hey Kurt,
I'll have to come round and check it out now that you've got her tuned up... I'm glad to see Marty got it all sorted out for you.
Do you still have a stock plastic intake pipe?
For eveyones info, Tassie dosn't have road worthy certs every year and I've never seen a 'defect' sticker... I've been driving heavily modified imports for 10 years. The only thing I've heard of is tickets for bald tyres, lights, loud exhausts and driving offences.
Oh and there's no limmit for p platers.
Cheers
Justin
cheers
Kurt
You may be able to get close to that (or maybe a bit more) if you use an adjustable fuel pressure reg.
Well scrap every thing i said about trying to hide it then.
Hey Kurt,
Cheers
Justin
I still have the plastic snorkle from the front to the box, Marty might still have the pipe that goes from the box to the plenum.
Send us a text on 0435 262 590. I've got tomorro off for once.
I've got a genuine Tomei Fuel Pressure Regulator, don't know if its adjustable or not, but i don know that all the modifcations done to the car were done with quality and reliability in mind.
Cheers
Kurt
tomei is adjustable, wind the top bolt (after undoing the lock nut) into the reg to increase the pressure, but only do this on the dyno right before a re tune and dont go crazy with the pressure.
Id get creative and re-install the airbox to plenum pipe to complete the stealth look. Cut the bottom out of it and slide it over the alluminium pipe.
Don't stress about the injectors.
I've got a stall convertor already. or will it not fit a new box?
Hey Kurt, don't you have a spare r31 auto box??? Your best bet would be to send the spare auto box away to get built up (more clutchs, bigger bands, shift kit etc) to handle the extra power... That way it will swap straight in without any buggering around... to put a 33gts-t auto in would be alot of stuffing around.. and it won't last as long as a properly build box anyway.
Cheers
Justin
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
