ah, my mechanic thinks we won't need one, it should cool down alot on it way back up to the engine but we'll see how it goes. If i need one i'll get one. Or if it's gonna improve performance i'll likely get one.
Who's putting it together for you? Then who's tuning it?
Tas is cold... but not that cold. to keep it stealth (Why stealth anyway??? just wondering) have a look at finned charge pipe work and/or water to air heat exchanger/intercooler.
I'd like to see a photo.
Cheers
Justin
  • Replies 206
As soon as i have more i'll put it up. The turbo has had the housing brough out or something which i think makes it spool easier. I've got a 2 and a quarter inch exhaust. The engine was n/a and the reason i'm running this set up is so the car looks standard. Don't want to get stickered now do we! I've got an auto box with a stall convertor of about 2500 rpm as i said before. Not sure if i've answered ever ones questions. Just ask them again if i haven't. If any one knows of a sly way to chuck in an intercooler or any other suggestions let me know.
Cheers fulla's.
For a sneaky cooler, run a water to air cooler up the front of the car with a radiator and electric pump in the front bar.
If you do it right it wont stand out too bad, and it will work tops.
Something along the lines of this:
http://www.pwr.com.au/images/intercoolers/4x6_kit.jpg
For a sneaky cooler, run a water to air cooler up the front of the car with a radiator and electric pump in the front bar. If you do it right it wont stand out too bad, and it will work tops. Something along the lines of this: http://www.pwr.com.au/images/intercoolers/4x6_kit.jpg
NEVER SEEN THAT BEFORE BUT I LOVE IT. I'LL BE GETTING ONTO THE MECHANIC ABOUT THAT ONE AS SOON AS I WAKE UP TOMORRO AFTER NIGHT SHIFT! CHEERS
Given the car was n/a and your using the stall convertor I personally think this sounds like a good option. Make sure you put up some pics of the install as well!
I'LL BE PUTTING SHIT LOADS OF PICS AND A FULL WRITE UP ON MODS AND DYNO RESULTS ONCE I GET THE CAR BACK. THANKS FOR THE FEED BACK THOUGH.
I'll take some photo's tomorro if i remember. Otherwise i don't think i'll hear the end of it. I've seen the you tube video from america but as far as i know i haven't heard of any of these in aus, especially tas. Hopefully it all goes well so i can pretend im the guru of sts. Haha. Don't recon i'll be fooling anyone.
its really taking off in the states, and there are a few cars over here too, mostly on commodores from what i've seen, maybe one or two falcons, all things with big motors though, hasnt proved so popular with 'smaller' motors *small by US standards, which is anything under 5L*
*lag* has proven to be not as big an issue as you would imagine it to be, plenty or cars coming on hard/quick/early
intercooling is not a necesity, but probly worth while in this case. running low boost, with an alloy pipe thats under the car with constant cool air moving over it has proven to be effective enough to not need a cooler, but if you can, put one in anyway :banana:
definately get pics and a dyno graph up
yeah i'll be running about 10 pounds of boost i think. There should be plenty of piping under there too. Sounds like i've got a few people keen to have a look at the final result. I'm thinking of chucking something in simular to whats in the link GTscotT put in above. Will see what we can all come up with.
Cheers fulla's.
Why would you get 'stickered' for a turbo conversion on a vl in Tassie? What is 'stickered'? a defect notice?
I think it's awsome that your doing somthing different, I'm just trying to work out the reasoning.
Can't wait to see the pic's
As I stated above, a water to air intercooler would be your most stealthy option. Hovever, a small air to air intercooler painted black behind the standard front bar would be almost un-noticable.
Also, you could cut your standard plastic intake and fitt the metal charge pipe inside to the throttle body.. then chuck a fake air filter on the end of it. ha ha ha
Justin.
yeah a sticker is a defect notice. And i've got an r31 not a wanna be vl. Haha. I'm going to see the mechanic later on today and throw a few more things at him, i think i may have already used up my budget but we shall see what happens. I've got little room in the front end because when i got the car it had a manual radiator so i had to put in an oil cooler for the transmition. I've been hanging out to get the car back and now im looking forward to sharing it with ya all. Gotta break the engine in before i can really have a go at it but oh well. I'm sure i'll be able to wait a little before i plant that right foot.
The cat has been gutted. The turbo should make it pretty quite until it spools up and the waste gate opens. I had a look at the setup the other day and it looks pretty tidy. Dirty big exhaust coming out of the turbo.
If ya want to have a look XRated we'll have to meet up and go for a cruise or something. I can't seem to find any skyline clubs in tas or even cruise groups so i've decided that one has to be started. That is of course if one doesn't already exist.
I should have some pics up late tomorro.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
