I've got an intermittent starting issue with the car - when I go to it turn over I get nothing. Literally nothing, not even cranking over. What I mean by "nothing" it's the same response you get when you try to start an automatic in gear. After a bit of removing and turning the key it it will start.
The fuel pump primes and the lights come on as normal but it just doesn't want to turn over. I have a Brant immobilizer (which is terrible on Subarus) on the car and I don't know if it is this or if it's something else.
It's been to an Auto Electrician a few times but no luck fixing it (he's re-soldered the Brant and this has helped it but hasn't fixed it).
Just wondering if any of you have had a similar issue?
Any help would be great.
https://www.sau.com.au/forums/topic/340188-car-not-starting/
i have the brant on mine and have had it for 8 years with no problems, thats not to say that thats not what it could be, might be starter motor my excavator is doing that when the machine is hot it is hit and miss starting if i turn it on and off a couple of times it will finally start. Next time it won,t start give the starter a good knock and then see if it starts
ok well there is two things the first is the auto elec would have checked for power to the trigger wire on the starter (small wire) and guessing that he then tried to find somthing inside the car it was not getting power so hitting the starter shouldnt do anything but leave dents. the other thiing to do is rewire the system with a relay, its very simple but you may have to bypass the immobiliser for the brant. If it plays up consistanly then the elec really should be able to sort it but somtimes on issues that are only intermittent it can take time.
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
