Hey, as title states, I'm after a JJR bellmouth dump/front pipe to suit S2 R33 GTS-t (RB25det). Same as this:
http://www.skylinesaustralia.com/forums/JJ...B2-t204414.html
Not fussy whether it's mild steel or stainless, but as long as it is in good condition (i.e no cracks, no dents etc). The cheaper it is, the better cos cash is starting to get abit tight now hehe :blush:
I'm located in Melbourne but am willing to pay for postage costs if interstate, so either reply to this thread or PM me :D
Cheers.
https://www.sau.com.au/forums/topic/340212-wtb-jjr-dumpfront-pipe-r33-gts-t/
Hi mate,
We have both in stock, brand new starting from $179.00 in Mild Steel and delivery to your door is no problem.
If you would like to place an order, simply follow the URL below:
http://www.justjap.com/store/home.php?cat=276
Feel free to contact me if you have any questions.
Cheers,
Steve
Hey mate, I've been looking at them for quite a while but figured it would be somewhere around the $190-$200 mark (mild steel) delivered to me (3806) and I don't have that money at the moment. If I did, I would be placing the order with you :ninja:
But since I don't have the $$$ just yet, I'm currently looking for a 2nd hand one. I'll see how I go, if nothing comes up for a while and I've managed to scrape the money together, I'll hit you up for one :)
Cheers.
What rhymes with "stump'?
BUMP!!
Haaaaaa :)
C'mon, surely someone has one laying around collecting dust and could do with some extra weekend money if they sold it to meeeee :)
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
