Hey guys figured this is probably the best place to post this.
Picked up an FJ package today, to myself appeared to be a regular FJ20et my room mate has had a few and thought it was factory turbo also.
Now i got it home and started stripping it down to to gauge its condition better and see if it needs a rebuild.
The first sign i found was the exhaust manifold studs are M8 rather than M10.
The most obvious sign was the inlet manifold has 'eccs' rather then 'turbo' stamped on it, the guy i bought it off said the inlet had been changed to make it fit better in the engine bay as its apparently smaller?
The oil feed for the turbo appears factory to me, not just a random hole drilled and tapped into the block. But this is my first FJ so im not sure if they use the same block NA and turbo?
When i pulled the rocker cover and sump off, i found the head has recently been rebuilt and new pistons installed (standard rods)
So basically, in your opinions does this sound like an NA engine with a turbo added? and is there an easy way to tell?
Also has anyone heard of this being done before and the results, shortened life span etc?
The engine will be going into my machinist in the next few days to be gone over thoroughly and compression ratios etc determined.
Anyways thanks for reading my novel look forward to learning a few things.
Cheers
Baffy
https://www.sau.com.au/forums/topic/340213-fj20et/
bit hard to tell if the engines not original unopened as parts couldve been swaped but yes with the smaller exhaust studs i would say the head is n/a tho turbo cams couldve been swaped in? or not. the oil feed is a banjo bolt on drivers side of block near starter and oil return is a large barbed fitting in block on passanger side just under stock turbo position > on an n/a block the boss is there but blank but would be possible to fit these with drill and tap tho would be easier to T oil feed off oil sender and return to mod'd sump like z18et and L6turbo motors. i havnt pulled my n/a engine apart but been told rods r slightly smaller, oil pump is smaller and pistons are different to change comp ratio. block casting,crank and bare head suppose 2b the same. my n/a engine has the short rocker cover not the normal high 1s and yes intake manifold has different word cast init, s12 silvia has shorter runner length.
hope thats some help
jon.
Edited by tir31
https://www.sau.com.au/forums/topic/340213-fj20et/#findComment-5505316
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
