Just curious on what everyone's opinion of the best P plate legal track car there is out there.
The criteria is:
1. Must be p-plate legal.
2. Must be affordable by your typical 18-21yo enthusiast. No S2000s, or track dedicated cars with trailers and separate daily drivers.
3. Must be a good car to actually learn in. No automatic cars, etc.
Modifications are allowed if they're reasonable and apart of the affordable budget (say 10-15k, bonus points for going cheap). Things I'm looking for are decent brakes, power, weight, handling, whether or not it has an LSD, etc.
I'm not actually looking to buy another car, I'm just bored and figured I try get some discussion going on the NA boards beyond which exhaust should I buy or how can I get more NA power.
https://www.sau.com.au/forums/topic/340222-best-p-plater-motorsport-car/
  • Replies 62
Posted Images
Toyota AE86 Sprinter with the 4age 16v.
RWD platform, light weight, high revving motor, good aftermarket support, use it for drift or circuit depending on setup. Cheap to maintain, cheap to repair, good street cred
Mr2's handle like ass, and not really something a novice could drive quick without going off the track backwards every 2nd lap.
Best bet would be MX5, AE86s require to much work to be really quick on a circuit, 944's are horridly expensive to maintain,
Early 1st Gen RX7's like to break gearboxes and diffs so would require expensive aftermarket gear to be reliable
NA S13 is another option, cheap as and no-one would care if you stuck it into a wall.
an Early Ex-tarmac rally escort with rego would be fun.
haha fair enough, I drove a TRD 4AGZE MR2 when i was on my P's (fair few years ago now), was a mad fun car just had to be really quick and confident on the wheel.
yeah I know what you mean, have a look at MR2 track day photos, 90% of the cars are covered in dirt and mud from going off the track, the few cars that aren't dirty weren't trying hard enough lol
R34 GT-V manual.
- Take out all seats
- Put some nice light weight wheels
- Heavy duty clutch
- Upgrade suspension
- High flow panel filter and cat
- External oil cooler
- Bigger radiator
- Thermo fans
- Catch can
- Light weight bonnet of some description
- Sticky tires
- Premium fluids
If budget permits
- Carbon driveshaft
- Light weight flywheel
- Slotted rotors
Trying to keep it legal with minimal mods.
Reasoning behind the R34
- Parts are readily available
- Lots of support from SAU
- Big brakes and LSD
- Ridgid body
- RB25DE NEO has reasonable torque and seems to rev out much faster (more responsive) than the older non NEO engines.
^^ Sounds like a list straight out of Gran Turismo
Hahaha.
Needs some stage 1, stage 2 etc etc
On a serious note.
- Keeping it legitimately street legal means you have to keep stock ECU (no nistune or anything like that) therefore - minimal mods
- The trick to anything being tracked is:
- Reliability.
- Being able to keep the engine within the powerband.
- Good brakes.
- Limited slip diff.
My friend's foster father has an old Peugeot 205 for track duties - his mods:
- Sparco driver's seat with harness
- Rear seat removed.
- Front passenger seat is removable.
- Battery moved to the back.
- Stripped out interior. All that remains is the climate control panel and cheap single din radio with 2 front speakers
- Runs on stock wheels with Dunlop semi slicks
- 1/2 cage
- Slotted rotors at the front with stock rotors on the rear
- Stock brakes with premium pads all round
- Koni shocks
- Larger radiator with twin thermo fans
- High flow filter and extractors (some other zorst work to I think)
- Stock engine
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
