Just curious on what everyone's opinion of the best P plate legal track car there is out there.
The criteria is:
1. Must be p-plate legal.
2. Must be affordable by your typical 18-21yo enthusiast. No S2000s, or track dedicated cars with trailers and separate daily drivers.
3. Must be a good car to actually learn in. No automatic cars, etc.
Modifications are allowed if they're reasonable and apart of the affordable budget (say 10-15k, bonus points for going cheap). Things I'm looking for are decent brakes, power, weight, handling, whether or not it has an LSD, etc.
I'm not actually looking to buy another car, I'm just bored and figured I try get some discussion going on the NA boards beyond which exhaust should I buy or how can I get more NA power.
https://www.sau.com.au/forums/topic/340222-best-p-plater-motorsport-car/
  • Replies 62
Posted Images
Toyota AE86 Sprinter with the 4age 16v.
RWD platform, light weight, high revving motor, good aftermarket support, use it for drift or circuit depending on setup. Cheap to maintain, cheap to repair, good street cred
Mr2's handle like ass, and not really something a novice could drive quick without going off the track backwards every 2nd lap.
Best bet would be MX5, AE86s require to much work to be really quick on a circuit, 944's are horridly expensive to maintain,
Early 1st Gen RX7's like to break gearboxes and diffs so would require expensive aftermarket gear to be reliable
NA S13 is another option, cheap as and no-one would care if you stuck it into a wall.
an Early Ex-tarmac rally escort with rego would be fun.
haha fair enough, I drove a TRD 4AGZE MR2 when i was on my P's (fair few years ago now), was a mad fun car just had to be really quick and confident on the wheel.
yeah I know what you mean, have a look at MR2 track day photos, 90% of the cars are covered in dirt and mud from going off the track, the few cars that aren't dirty weren't trying hard enough lol
R34 GT-V manual.
- Take out all seats
- Put some nice light weight wheels
- Heavy duty clutch
- Upgrade suspension
- High flow panel filter and cat
- External oil cooler
- Bigger radiator
- Thermo fans
- Catch can
- Light weight bonnet of some description
- Sticky tires
- Premium fluids
If budget permits
- Carbon driveshaft
- Light weight flywheel
- Slotted rotors
Trying to keep it legal with minimal mods.
Reasoning behind the R34
- Parts are readily available
- Lots of support from SAU
- Big brakes and LSD
- Ridgid body
- RB25DE NEO has reasonable torque and seems to rev out much faster (more responsive) than the older non NEO engines.
^^ Sounds like a list straight out of Gran Turismo
Hahaha.
Needs some stage 1, stage 2 etc etc
On a serious note.
- Keeping it legitimately street legal means you have to keep stock ECU (no nistune or anything like that) therefore - minimal mods
- The trick to anything being tracked is:
- Reliability.
- Being able to keep the engine within the powerband.
- Good brakes.
- Limited slip diff.
My friend's foster father has an old Peugeot 205 for track duties - his mods:
- Sparco driver's seat with harness
- Rear seat removed.
- Front passenger seat is removable.
- Battery moved to the back.
- Stripped out interior. All that remains is the climate control panel and cheap single din radio with 2 front speakers
- Runs on stock wheels with Dunlop semi slicks
- 1/2 cage
- Slotted rotors at the front with stock rotors on the rear
- Stock brakes with premium pads all round
- Koni shocks
- Larger radiator with twin thermo fans
- High flow filter and extractors (some other zorst work to I think)
- Stock engine
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
