Rb25det Engine Parts, Head, Pistons,sump,plenum & Other Engine Parts
Parts for sale in coopers plains Brisbane 4108.
Came from a car I purchased from a friend who blew the engine by upping the boost and not tuning it, and through a con-rod out the side of the block.
The head comes with a one month money back guarantee if its found to be cracked or not usable. There are slight marking on one of the cylinder have a look in the very detailed pics on the link, shouldn't affect the function of the engine.
The sump has a very slight dint which with a gentle tap should be able to be brought back to perfect.
One of the 5 pistons has a slight mark on the back of it, there is a pic of it also, the other 4 look to be in perfect condition.
Any questions best to send it to [email protected] for a quick reply, or phone 0424631188.
Pics of engine parts RB25DET - this is the link to high quality pics.
Rb25det head, valves, and cams $200.
Upper and lower plenum and throttle body $100.
Cam covers $40.
Crank sprocket $10.
Cam sprockets $40.
Oil pump $30.
Oil strainer $5.
Pistons $15 each.
Water pump $20.
Rear cam belt cover $10.
Sump good condition $50.
Rear oil seal housing $10.
Thanks for looking. :blush:
Rb25det head, valves, and cams $200.SOLD
Cam covers $40.SOLD
Crank sprocket $10.
Cam sprockets $40.
Oil pump $30.
Oil strainer $5.
Pistons $15 each.
Water pump $20.
Parts for sale in coopers plains Brisbane 4108. :)
Cam covers $40.SOLD
Rear cam belt cover $10.SOLD
Cam sprockets $40.
Crank sprocket $10.
Oil pump $20. - Price drop
Water pump $15. - Price drop
Pistons - $15 each.
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
:cheers:UPDATE: PRICE DROP!!!!! :cheers:
Parts for sale in Coopers Plains Brisbane 4108. :)
Cam covers $40.SOLD
Upper and lower plenum and throttle body $75 Price drop
Sump good condition $35 Price drop
Cam sprockets $20 pair, Price drop
Crank sprocket $10.
Oil pump $20. Price drop
Water pump $10.Price drop
Pistons - $10 each, Price drop
Rear oil seal housing $5 price drop
Edited by Bris33
  • 3 months later...
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
