Hey guys need your help, Bare with me im new at this. I bought an R33 GTST about a week ago. Since then ive bought a Drifft Iridium boost gauge to install all went well with the electrical wiring im handy with that stuff. Now over to the engine bay. My car already had a boost gauge fitted to it by the previous owner but he removed it. I thought id just attatch the metter to where it used to be from the old owner to get it to run.. An sucssess it lite up. I was happy with it. Now here is where the problem lies. Just 2 things.
1. On my boost gauge it reads Negative 16 (-16) on idle is that normal??
2. I took it out for a test run and felt the car splutter and sound like it wants to stall. Now i know i have a coilpack problem im waiting for a new 1 to arrive. Prior to the new gauge id get a bit of a miss at 4500rpm . Though Since i installed the new gauge and have it hooked up the problem feels more severe.
as soon as i take the vacume hose off the aftermarket gauge it returns to normal. Have i hooked up the meter incorectly?? ive never done this bfor and thought id give it a shot since i already had the t piece and followed the disconected hose. PLZ help
https://www.sau.com.au/forums/topic/340243-boost-gauge-reading-wrong/
**bump**
From what you describe, it sounds to me like a vac leak. It makes Nissans want to stall when returning to idle. Check your vac connections and check that the gauge is sealed properly.
Hope that helps :banana:
kool ill give it a shot was hoping that i didnt conect it wrong lol well i didnt conect it at all lol last owner did. Just to be clear on it the set up on my RB is like this... I have a vacume hose coming out of the plenium which is then hooked up to the T Piece. From the bottom of the T piece i have another hose running to the BOV then from the otherside of the T piece i have a hose running to my Boost gauge
kool on another note what should the boost be reading on idle?? -7 like the stock gauge? and what size hosses should i run? i may have to replace t piece as the hosses that link up to it from the previouse owner are quite large compared to the little gold fitting i got for my boost gauge
OK so i bought a new t piece and new vacume lines and tried it again and its still doing it also my new coilpack came in 2day so ill fit that on saturday and see if anything changes... I hope it fixes the problem... ill let ya know by sat arvo.. also if anyone knows any other reasons this is happning plz fill me in.. im scared ill damage something expensive
My gauge reads -20, my greedy elec boost thingie reads -99 (about -10 psi) but both read 16 psi on full boost.
I think the - doesnt really matter but I could and have been wrong....
so if any of the piping from the intercooller can make the engine splutter ayy?? well when i just disconect the hose leading to my boost gauge everything runs normal.. by the way my gauge is digital not mechanical.. just thought mayb that info would make a difference
yea u see im getting -16 on idle when i take of and rev i think i can get to mayb 5 or 7 then when i back off it drops down to -21 then goes back to -16 i bought the gauge to find out what sort of boost im running lol i thought the gauge would tell me on iddle.... i really dont knonw how to find out wat boost im runnning can anyone fill me in??
from what i know u will always get a negative readin on idle. If you want to know what boost you're running then get a mate to sit with you while u accelerate (hard) the gauge will rise and show you your max boost. hope that helps
kool ill give that a shot. Also i forgot to mention in my post since changing the vaccume hosses ive noticed like a BOV flutter but its coming from the pod flter is that bad ive heard about people blocking some pipes or hosses to get that sound and apparently it forces air the wrong way to the compressor and spins the turbine the wrong way
OK flutter is gone the hosses i used were to small so i bought turbosmart vac hoses and fixed it up also i was at utobarn today and the guy pointed out that the hose from my acctuator is left like a breather he told me to take the heatshield offf the turbo and reconect it to the housing but i cant find the nozzle in the end i simply reconected the carbon canaster does the stock acctuator link up to the turbo housing???
ohh and still no result in linking the boost gauge up. So i guess ill have to search for a boost leak. Whats the best way to find it??. Also another thing ive been told that it could be overfuelling making it sputter on boost ive checked the engine bay and reved her a few times and i did smell a lil bit of fuel.. does anyone know how to fix the issue if it is overfuelling??
Sorry for the bombardment of questions iots just starting to get a lil fustrating
  • 7 months later...
Mine currently sits on -15/16 during idle. All my previous turbo cars sat around that mark on the boost gauge during idle so I'm assuming it's pretty normal and you have got nothing to worry about. I had a vacuum leak once and it sat on like -5, but once I fixed the leak it went back to -15 again.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
