hey guys i have seen this car before and have been searching for a pic so that i can describe what i am after as most people have no idea,
well i found a pic courtesy of the r32 skyline cruise to katoomba here is what i am after
the headlight surround will offset my orange r32 verey well as i have black corner indicators
any help would be much appreciated
yt
https://www.sau.com.au/forums/topic/340254-headlight-inserts/
Yes that would be a cheaper option to making them from scratch, but I have never seen them for the drivers side, only the passenger as that's where the intake is.
ha that was going to be my next question, oh well back to the drawing board i guess
You can try get them from Autostyle in Sydney cos with more or less all their R32 GTRs, they do the quad-headlight as above in the pic. I'm not sure if they will sell it to you directly though, but you can give it a go.
Also, apparently your headlight lighting becomes fairly poor when you fit those as you dont have the refelctors anymore (could also be a defect too? Not sure on that one).
Edited by turbodragon
I got them on my blue r32 from autostyle you can by mine if you buy the car :) but auto wont sell them seperately. As for the lighting they produce, no issues at all not dull or anything but i do have HID's in there...
I got them on my blue r32 from autostyle you can by mine if you buy the car :banana: but auto wont sell them seperately. As for the lighting they produce, no issues at all not dull or anything but i do have HID's in there...
dammit, ok who wants to try and make one for me/with me??
Edited by Yts
give this topic a read
http://www.skylinesaustralia.com/forums/R3...lear+indicators
you could get something along the lines of infinity headlights which are shown at post #5 and #6 or follow this diy and make your own
cheers
found this thru a search on sau ;
Those headlights are made by Infiniti in japan. However inifiniti don't make them anymore, but they do pop up secondhand from time to time. Autostyle have moulded the infiniti lights (which from memory came on a car they imported a while back) and fit them to their demo cars. If the original inifiniti's are anything to go by those headlights are shocking. I wouldn't be using them on a road car.
They're also illegal to use in australia as they don't have a low beam diffractor, or park lights.
http://www.skylinesaustralia.com/forums/R3...hts-t97453.html
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
