Have just finished fitting GT2860-9s to my car, when cruising along in 5th at 100ish going up hills with light load it starts making a sound like a steam train, it does not surge power wise, but it just makes this noise for as long as I hold it on light throttle, so I back off, it stops, accelerate, still not there, lift off to hold 100k, it starts again.. It did used to do the same with stock turbos but rarely, and not as bad.
Questions:
Is it compressor surge?
Apart from being bloody annoying is it doing any damage?
With a PFC and a tune will it be possible to get rid of it? (or what will?)
https://www.sau.com.au/forums/topic/340270-is-is-compressor-surge/
Its a typical GTR problem, but my soarer also does it sometimes,
Its because the Dash-9s in your case want to spool up very quickly, but the engine cant swallow it so it spits the excess air back out the turbo inlet, which slows 1 turbo down as the air comes back out then vice versa with the 2nd turbo.
Do you have the standard Bovs on the car or aftermarket ones? the standard ones are always open when the intake is under vacume to help prevent this.
hey mate yeah mine does exactly the same thing ive got gtss(same same -9) apexi intake and still have the standard bovs. Mine does it at zero vacuum and i was thinking that it was the bovs opening a little and air flowing through them but i havnt tested this theory. i might have a play next week.
I dont think its anything to worry about but up a slight hill it can be a bit annoying.
Apexi pods and turbos are the only mods, does it on any boost setting (7,12,18). Turbo shuffle sounds far more likely, that is the noise I am getting, remember hearing talk about it previously but had forgotten until GTScotT mentioned it. Definately not the induction noise.
does it go away when you put your foot down? my -5's with apexi pods do the same sort of thing at around 3.5-4k, i think its just something to do with the way the exhaust housing is designed.
  • 2 months later...
This basically happens when the engines displacement is too small for the turbo application. What you need to do is think of it a little like this. An rb26 with twin turbos is essentially like having x2 1300cc displacement engines with single turbos on each (which in most cases is too large for the displacement. As you can imagine as you increase the turbo size (say gtrs's, -10's or even -5's) your tubro shuffle, compressor surge or axi-symmetrical compressor stall (what ever the hell you want to call it) will get worse. Hence why almost all gtr's fitted with gtr's or -10's will shuffle at some point in the rev range. Get an sr20 slap on one of the said turbo's to it and you wont see that type of shuffle (2000cc displacement engine running a turbo more efficient for its displacement).
Now on how to try cure it. You can increase tge turbine housing to try slow the compressor down, (or use smaller turbos), but here you will run into another dilema, LAG. You can increase the engine displacement (why you generally wont here shuffle on a rb30/26 engine with -10's etcetc). You can try have your tuner tune it out, baffled turbo pipes etcetc. But the most effective way ive found is to use a 3 dimensional boostcontroller. Its basically an electronic controlled solenoid (by the ECM) with an rpm input ( which alters the duty cycle of the boost control valve as the RPM changes), and a throttle position sensor input (tells the turbo how much power the drive is demanding and essentially tells the turbo how much air the engine is capable of swallowing to avoid such a surge). 9 times out of 10 this will work.
p.s ( i love brackets)
(same)
u can also try lowering the gain setting or start boost dependong on ur boost controller. This helped with mine it makes the turbos slightly laggier but helps prevent choo choo train.
i have n1 's. Sunce changin bac to stock intakes it is gone completely
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
