anyone has one for sale?
been looking for 1..
heard lots of stuff that the s13 ones dont fit.. (due to sump clearance)
what abt GTR swaybar? would they affect the handling? (mounting points are different)
s13 is the same just go buy em from bursons
ive got an rb engine... i would be perfectly sure if i got sr in mine..
have you tried yourself kris?
there havent been any definite discussions about this one..
ordering it from selbys would be the perfect option, but they went bankrupt right?
The S13 swaybar just touches the sump in a A31.
I belive whiteline took over the selbys line and now are back in action.
so is it actually wearable??
well i went to autobarn and they said they dont make it for a31..
if it touches, it will slam the sump when the swaybar moves does it? if i hit a corner, it will flex for sure
for the ten billionth time, s13 will not fit! neither will anything else. GTR mount points are different (I think) cause of the upper control arm and different knuckle design.
A31 is a unique, one-of shape. I have contacted Fulcrum asking what the f*@# happened to selbys and all they said was they will be producing sway bars using all teh old selbys gear and info but they haven't started producing the sway bars yet. As far as I understand they moved into the old selbys shop in Sydney. I found a web page the other week claiming they have the selbys family working for them, producing custom sway bars. I'll try and find it again.
Edited by RBceffy25
Mine had a S13 bar in it, compared to a stock ceff swaybar, the part where it bends around the sump area is a few inchs shorter than A31, hence the s13 just touching the sump.
I would be still using it if it didnt foul my 6.5 ltr sump, the stock ceff swaybar also hits my sump :)
Kris has a S13 swaybar in his A31, post so pics up for us man.
Toffy runs a 32 GTR front swaybar with no hassles?
Edited by works 510
s13 will fit the suspension geometry and it will definitely work well with SR20 engine...
currntly stuck wit the rb20 but if i use swaybars exactly for a31 i would still be able to use it for the sr20
so selby is still stuck with the finances...
id take any custom made ones.. i wonder what huddy put on his ceffy
well fu@# me....... I dont know how many of these exact threads i have read about ceffy swaybars but no one ever has straight answers.....
until now :P
Pics please?
Yes of course it would fit perfectly with an SR... I think thats the whole point we are all trying to make
If any one is interested, all I need Is a standard front sway bar and have it sent to a guy I found to use as a template/sample. Then we can all have actual heavy duty, adjustable 27mm A31 Cefiro swaybars!:P
If any one is interested, all I need Is a standard front sway bar and have it sent to a guy I found to use as a template/sample. Then we can all have actual heavy duty, adjustable 27mm A31 Cefiro swaybars!:)
So no-one has one?
C'mon people! Real, actual A31 front sway bar!
selbies make them i had one ordered, it was delivered about a fortnight ago but im splitting cats car up. I just sold it over the weekend.
I would be still using it if it didnt foul my 6.5 ltr sump, the stock ceff swaybar also hits my sump :P
yep , fits perfect , all you have to do is bolt it to the lca instead of the strut (let the connecting arm hang down instead of up) . simple , so i'm assuming r32/s13 are very similar and should fit , when i start stripping my car down i will take pics and post up a thread instead of spamming lol
do you have the contact number? i saw fulcrum website they said they took selbys and puts them back to life.. but then i emailed them to order it n then nothing happens :s
called them and they said they gonna call me back... dont hear shit from them since then..
if you have any more custom made front sway bar, id be happy to be your trash can :ermm:
oh and is the front tension bar important as well? i saw kris had it fitted on his..
just wanna know if its worth my 150 bucks
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
