m35 stagea 2002
I received an email from the company doing my compliance.
They wrote:
Stagea’s are common for wearing out the front lower control arm bush, which would deny it a safety certificate until replaced
I am unsure of what that means but is this something that is easily sourced and simple to replace or is a special Nissan part required?
can i strengthen or upgrade this without affecting compliance.
What is the function of this part/unit?
Although my car hasn't landed yet I need to get prepared as i
don't have a lot of time due to my intended driving holiday.
Thanks in advance
Edited by samuri
https://www.sau.com.au/forums/topic/340283-worn-control-arm-bushes-whats-that/
m35 stagea 2002
They wrote:
Stagea's are common for wearing out the front lower control arm bush, which would deny it a safety certificate until replaced
Thanks in advance
funny you mention this.. if its the same busher im replacing on both sides thats making my front suspension creak pm on my m35!
if it is the same piece your talking about that wears , its generally a t -piece like bolt sleeved with a busher over it that connects a control arm and tie arm together. i purchased 2 from nissan for $55 inc gst.
probably going to cost me $100 give or take to install at the suspension shop.
hope that helps... ive got a breakdown of the whole front suspension diagram somewhere ill scan it up when found.
This part?
is thats what your saying about the creaking and etc? i've been annoyed with that for ages
can you take photos of what you've bought and the part numbers soon??
These same bushes get dry on C34's and creak away...
Drop wheel, remove bolt carefully, two spring assisted seals on each end remove these, pull out the insert re-grease everything bolt back up and should be sweet :-)
sorry to hyjak but it might be relevant
The rubber part on the car i am pointing to is pretty flogged also.. i was thinking of using some polyurethane stuff i have here that i used many years ago to make solid engine mounts in my gtir..
but i am unsure if thats my issue of knocking sounds in the front left
heres what the arm looks like off the car.
Great
thanks.
This part?
is that what your saying about the creaking and etc? i've been annoyed with that for ages
Thanks . the photo is very useful
Edited by samuri
  • 2 years later...
Yes I am in the same boat, but when I contacted nissan they want to order the entire control arm and not just the bush! Nissan want to charge $400 for one side!
I'm despirately trying to locate someone who can sell me just the rear bush in the front lower control arm but it's proving to be harder than I thought. I've tried a few places but they only have them for the 2 wheel drive version or only the M34 where I have the M35 AWD
Cheers
Micah
Just FYI- you'll need someone with a press to get that in for you. Its not a push in kinda part, cut out the old one, and press in the new one. Also suggest getting the ones with the castor offset ;)
With the offset bushes, as with the swaybars, BC's and underbody bracing, the car keeps getting noticeably better turn in. I can't believe how much better the handling has become from the saggy whale like feel it had when I bought it.
Highly recommended.
I replaced mine about 15k ago. In my previous Axis I did the mistake of putting in custom made nolathane bushes, never ever again, over speed humps and up driveways squeeked like a mofo.
I got mine as the hole arm with bush pressed in, the bush is sort of actually moulded to the arm, original from Nissan Japan, price was $144 AUD per side
54468N (RH)
54469 (LH)
Only squeak I have is somewhere in the back, but haven't replaced any bushes back there.
Check boot for backpacker.
Re-tie mouth gag.
Dispose of body.
No more squeak.
You're welcome.
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
