  • 3 years later...
Apologies for thread dredge... but my Stagea needs lower control arm bushes done.
Doing a bit of reading here and elsewhere it seems SuperPro are the aftermarket option and it appears SuperCheap Nz does supply that brand.
Couple questions, is it a fairly straightforward job to DIY, haven't mucked about with car suspension bits before. And anyone else done same, part number etc???
2005 PM35 350RX
Haven't done much more than poke my head behind wheel for quick look so far... Other than that shes been running well.
I ordered my Stagea control arm bushes from SuperPro in Brisbane online, they were a great help!
I did also find some on ebay here... http://www.ebay.com.au/itm/SUPERPRO-FOR-NISSAN-STAGEA-M35-AWD-RWD-Control-Arm-Lower-Inner-Bush-Kit-/141973305710?hash=item210e44b96e:g:4QoAAOSwaZdXID5Y
You can also order direct from Nissan Online and have them shipped straight to you here... http://www.nissanparts.com.au/stagea_nissan/nissan_stagea.html they are great too! Often they have the parts locally they can send to you pretty quick.
I'm not sure about making them yourself, but I did have a mechanic offer to make them for me when I could not find them so it must be able to be done.
Cheers Stagea Brother!
Cheers. Yeah my mechanic said Nolathene agent in Auckland custom make stuff if you give them sizes. What ive read so far seems like superpro is the go and I'll just have to remove/cut out the old one and get a workshop to press in the new ones.
BTW I previously posted here as Shopping Trolley in past but buggereed up me email/logins trying to recover password.
  • Like 1
  • 5 months later...
Old thread, I know, didn't want to make another one considering it's been mentioned in here but I can't find a link to one. Does anyone have a diagram of all the suspension part numbers and bushes? I am going to be replacing basically all the rubber underneath and was hoping for a diag to help me in my search. Also does anyone know the P/Ns for diff mounts, etc?
Thanks.
Sorry I cannot find it, it was the guys at VON Bibra Holden on the Gold Coast that sent it to me, maybe drop them a  line, they are really good with Stagea parts, also maybe ask at http://www.nissanparts.com.au/stagea_nissan/nissan_stagea.html  when you complete this form you end up being contacted by VON Bibra Holden.
Hope this helps.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
