hi all, few months ago i purchaced a clean as r32 gtr v-spec 93 model. It came with 18 inch bbs wheels, usual brembos :rofl:, thicker strut braces, full exhaust from front pipe back, and awesome Aragosta coilovers :) :).
So far all iv done is replace the spark plugs, all bushes are new and compression check the motor which came up all really close, and remove the boost restrictor which suprisingly made a nice difference :) Next mod im getting is some dba motorsport slotted disks and project mu pads, then some front camber arms:)
At the moment im looking at getting a new frontpipe and some aftermarket split dump pipes while im in there. Was wondering if anyone knows of a brand of front pipe which sits relatively high under the chassis and doesnt cost a fortune?? Not after titanium as its way to $$$. The front pipe i have at the moment sits a bit on the illigal side and im not after anymore defects.
Im also chasing some nismo LMGT1, LMGT2, LMGT4 or BBS-lm wheels as id love to be running a set of any of these in 18x10 but they seem real difficult to come across a decent set in gtr size.
Also wondering if anyone knows what benifits if any are to be had by getting a stainless steel exhaust manifold on the standard turbos.
heres a pic to show which i dont wanna have to wind those coilovers up despite the exhaust being 7 cm of the ground :P
https://www.sau.com.au/forums/topic/340286-32-gtr-v-spec/
- http://www.skylinesaustralia.com/forums/JJ...=gtr+front+pipe
$299 for Front Pipes.
+ I think it is $30 postage..?
- http://www.skylinesaustralia.com/forums/Ne...to-t337147.html
Brand new Nismo LM GT4 in Bronze. 18 x 10.5" +15. $4400.
Not the exact size you want but Aaron has more wheels in stock.
No point in changing the exhaust manifold if you are running stock turbos.
https://www.sau.com.au/forums/topic/340286-32-gtr-v-spec/#findComment-5494678
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
